jeremi3210
pto clutch glue
jeremi3210
What kind of glue do you use to replace the friction meterail on a pto clutch?
Wheel-N-It
  • Good question. I'm looking forward to the experts on this jumping in with an answer.
groundhog47
Had a similar post few back, found a tuffbond 230, US outlet unfound, another fellow WHRS member uses some two part epoxy, will get back
Don1977
You need something like what they use to bond brake lining to the shoes. I have looked on the internet for answers but haven't found any. I guess they are afraid someone will do a sorry job and then sue them. Some body ask about a product but it's only made in India don't remember the name, couldn't find any place that sales it.
It will have to be an epoxy that can still hold when it gets real hot.
groundhog47
Devcon 5 is what he uses, I tried the place in New Jersey that seels a product, but by the Quart, wow how many clutches could we build. An alternative is copy the old style with rivets, which I will do one that way. The countersink I,ve not worked out yet. The other is bonded. Our local clutch and drive shaft people only rivet; another they referred bonds but haven't contacted them yet. On the brake band I would like to rivet top, bond rest. The PTO brake will prob rivet only.
Please keep us posted, some say clutches are cheap, but I like a little thicker and "I want it NOW" instead of big $ shippin'.
Don1977
Another thing that can cause problems. I have a 1977 C-120 bought a PTO replace clutch disk and kept wearing out C-clips. The metal disk was 1/16" thinner the original. On the third set of C-clips a made 1/16" thick washer and drilled the 4 mounting holes and place it between the clutch disk and pulley.
tarcoleo
The PTO clutch is used so lightly in any normal situation that
heat build-up should not be a problem for a good quality epoxy
such as JB. That said, I would rivet the lining just to be sure.
McMaster-Carr sells friction material that can be cut to size and
countersunk easily. They may even be able to advise or sell an
adhesive for the application. I haven't talked to them but it might
be a good idea.
Tom
TT
Anabond 230 is what I found, but it looks tough to get.
Here's a thread from a while ago that discusses having them done by professionals:
JC 1965
Will the friction material from McMaster- Carr work for the brake lining also ? :confusion-shrug: If not, does anyone know where I can find some brake lining material. :hide:
tarcoleo
http://www.mcmaster.com/#catalog/118/3511/=kznz5t
The medium stuff 1" wide is what I used on the brake band,
epoxyed and riveted. Heating in a toaster oven allowed the
material to be curved. The friction material for the PTO clutch
has not been tried, but shouldn't be too difficult with
good common mechanic sense.
Tom
groundhog47
be a good idea.
Tom
They do sell epoxies and I haven't asked for their help on that yet. I got the 1/4" friction material which may be to thick, but it sure looks strong/durable. JB industro weld was recomended by one, not sure who yet. In discussion with others our concerns are more gas and oil related along with heat, even though gas/oil would be infintesimal and heat ? slipping heat is the only concern but readjust should fix that. Apologies Jeremi, don't intend a hijack here!
groundhog47
I puhchased the Mc..- Carr high friction material. It has fiberglass feeling to it with woven in brass, sorta like my original if it really is. It took some time moulding it to shape, but I see here someone mentions T...Oven, shuda tried that. Prob enough left over to do clutch brake too.
roscoemi
I use devcon home 2 part epoxy, from do it best hardware stores. Mix 50/50, and mix it with some authority to get it mixed and set off the chemical reaction. Apply, adhere and add weight. Can use in an hour.
Butch
I think Duke has relined brakes and PTOs. I would check with him.
tarcoleo
Well, here's a best guess on a high-temp epoxy that likely can do the job at least
as well as any other--a private opinion. Loctite has a fine reputation for their products.
http://www.amazon.com/Loctite-Hysol-Epoxy-Adhesive-PRICE/dp/B004VODQ0M
As suggested above, use rivets (brass) on clutch discs and brake bands and
you should be fine.
Tom
