repairman
modified 1054 work tractor
repairman
14 HP M 6 speed gear box 15" Jeep Wheels 42" snowblower
its been alot of work thanks for looking.
repairman
more pics
repairman
15" jeep wheels turned inside out
Jake Kuhn
Very nice! I like your tail lights, what are they off of?
855ownerJoel
Not to critique, but I think you will need some chains on those wheels or you will just spin your tires when trying to blow the snow. Nice tractor, I have a 1054 also, I put a 12HP on mine. One tough machine!!!!
buckrancher
looks like in the second picture down from top with snowblower I see tire chains
855ownerJoel
I stand corrected.
3609horse
I had one with a worn transmission and thought of putting a 6 speed in but the bolt pattern didnt match, did you redrill the trans or the frame to make it fit?
It looks nice , now I wish I never sold mine. Gene....
953 nut
I put a 6 speed in one of my 953s a few years back and redrilled and tapped one transmision hole and redrilled one frame hole, not too hard. I used rims from a FWD Ford mini van on the 5 lug hubs, just turned them around so they went outward.
Hope this helps.
