lilredpuller8 11 #1 Posted January 3, 2013 Ok somewhat un - horse related since it is on a power king, nut i feel like I come to the right place with questions like this. I have this 18 hp K series and its OHV. I have had no luck with it what so ever. The old guy i bought it off of said the points would always close up. No problem right? easy fix.... NOPE. It runs like it just looses itself and bogs oiut with a half hr of running. so i replaced the condenser, coil, ballast resistor, key switch, fuel line, fuel pump, re did the carb several times, new head gasket and reground the valves. And some how or another it still does the same thing. The head gasket and valves helped but it still gets out of hand. Any suggestions? im lost on this one and i consider myself to be a pretty good troubleshooter when it comes to things like this but right now im at a loss. HELPPPP!!!!!!!!!!!!! Share this post Link to post Share on other sites
Stepney 2,357 #2 Posted January 3, 2013 Well, I'm no expert. But I had a '74 Economy, and it didn't have a ballast resistor, it had a Solid State coil. But, I've had that happen too, and I found it was the condensor. I did have a dud, once. But I don't know. Spenser Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted January 3, 2013 the points would always close up. What exactly does that mean ? the points stay in good electrical condition but the physical gap closes down ? the points arc over and weld together? not sure what to suggest as those two conditions would dictate two entirely different troubleshooting approaches. Share this post Link to post Share on other sites
lilredpuller8 11 #4 Posted January 3, 2013 I tired it both with and with out the resistor and still same results. What i mean when the points close up is some how or another where it adjusts would come loose and slide untill they closed all the way up. I also tired a different condenser and even tired it in different spots on the block no luck. :banghead: Share this post Link to post Share on other sites
Wheel-N-It 2,976 #5 Posted January 4, 2013 Are the threads stripped on that screw (or where the screw threads in) that holds the points to the proper setting? If those threads are stripped then changing anything else is a waste of time until you get the points to hold their adjustment. 1 Share this post Link to post Share on other sites
lilredpuller8 11 #6 Posted January 5, 2013 One of the first things i changed was the points. All the items mentioned in the posting i replaced. Im stuck now i broke it down to all them things and still didnt help Share this post Link to post Share on other sites
roscoemi 245 #7 Posted January 6, 2013 Like Wheel-N-It said, if the points don't stay in adjustment your wasting time on anything else. Share this post Link to post Share on other sites
