Cvans
Charger Auto Question
Cvans
I've been searching for quite and while and come up empty handy. I have a charger automatic and I'm not familiar with the manual relief valve on the Suntrand. All the manuals I've checked here say to follow the direction on the decal before towing. Someone painted over the decals so I can't read it. Is this a Quarter turn valve, Half turn, or do you screw it all the way in to drive the tractor under it's own power?
Thanks for your help.
jdog_kustoms
half turn
it just spins around and around
steve k
yep jdog is correct. Half turn valve. with it straight forward/backward one way you can push the tractor, turn it 180 degrees and it should not roll when pushed(or at least roll hard)
Cvans
Thanks for your help. I really appreciate it.
It didn't seem like it was threaded but somewhere I read that it needed to be screwed in for one of the functions and mine didn't do that.
Ed Kennell
Thats for the other sundstrand that has the relief valve with the slotted stem behind the left foot rest. Screw in to run----out to push.
