JimmyJam
K181 -Shooting sparks
JimmyJam
I did my weekly fire-up of my 1976 B-80 with a K181s. I recently purchased it: changed oil, new gas, new spark plug. I tweeked the carb adjustments because it was running a bit rough and then noticed red-hot embers (sparks-like) randomly flying out of the muffler (not a stock muffler). What causes that?
Sparky
How long and where was it sitting before you got it? Could a critter (mouse) have deposited stuff like grass/sticks/acorns in the muffler and now your burning it off?
Mike..........
Don1977
Could be rust burning loose and shooting out.
AMC RULES
Whatever it is, it'll burn off, and stop shortly...probably just blowin' out it's birthday candle...happy to be reborn. :occasion-candle:
buckrancher
could be loose carbon and some rust burning off
brian
JimmyJam
Thanks guys! I want to restore it back with TLC, but it is my snow plow worker. I know it needs new things: gas lines, gas filter, NOS muffler, etc. Should I put Seafoam in gas tank? Will it help? I religiously fire it up every Saturday and give it several spins around the yard; sometimes twice a week. It fires right up in the first crank, and not much choke. She wants to go!!! Without the plow, I'll bet it'll want to pop wheelies!!!!
Duff
I've found Seafoam to be a very good additive. There are some excellent threads on the forum about it.
Cheers!
Duff :thumbs:
tunahead72
If you're going to use SeaFoam (or any other additive), I would go ahead and replace the fuel lines and add an inline filter first. SeaFoam will loosen dirt and debris in the fuel tank, if you don't have a filter that junk will go straight to the carb and gunk it up.
