Fast N Red 5 #1 Posted December 26, 2012 Ok guys to my last pull was a while back. I decided to pull the motor apart and start both builds but does any one know were i can get a .330 lift cam my stock alterd is put off till them Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted December 26, 2012 Vogel Manufacturing has cams: http://www.vogelmanufacturing.com/shop/garden-tractor/engine-parts-kohler/camshaftsandvalvetrain-1.html So does Lakota: http://www.lakotaracing.com/cams.htm Share this post Link to post Share on other sites
Jim_M 179 #3 Posted December 26, 2012 Greg Hackman has the best cam right now in my opinion. http://www.smallenginesofseymour.com/camshafts.html Share this post Link to post Share on other sites
Fast N Red 5 #4 Posted December 26, 2012 Vogel Manufacturing has cams: http://www.vogelmanu...lvetrain-1.html So does Lakota: http://www.lakotaracing.com/cams.htm Vogels cams are .340 lift and i dont feel like sending my cam in the getting it reground again to .330 Share this post Link to post Share on other sites
Fast N Red 5 #5 Posted December 26, 2012 Greg Hackman has the best cam right now in my opinion. http://www.smallengi.../camshafts.html i bought my used Holley fuel pump of him in the box he send my a printed out catalog full of goodies Share this post Link to post Share on other sites
Jim_M 179 #6 Posted December 26, 2012 I've got a Hackman cam in my tractor and it's been the points champion for the last 2 years. I'm building another tractor right now, V twin, and it also has a Hackman cam in it. 1 Share this post Link to post Share on other sites
baerpath 517 #7 Posted December 27, 2012 Have you tried http://www.easternga...assifiedads.htm There's some other clubs sites on the page under Orange County PullersNew Lakota V-twin 330 (525) lift roller cam. Sold new $600. Buy it now $300. Duane Share this post Link to post Share on other sites
Jim_M 179 #8 Posted December 27, 2012 (edited) Do they check the lift at the valves when they tech your engine? I run a .340 lift cam with more clearance in the tappets. Keep adjusting and checking until you get the .330 lift. It won't be nearly as much clearance as you think. I have a slight click at an idle when cold but it gets a little better when it warms up . Some of it due to strong valve springs, some due to cam profile and some due to the tappet clearance. I'm not changing anything though, it runs like a bear. I think the cam grinders are optimistic when they list them as .340 lift. Edited December 27, 2012 by Jim_M Share this post Link to post Share on other sites
Fast N Red 5 #9 Posted December 27, 2012 Do they check the lift at the valves when they tech your engine? I run a .340 lift cam with more clearance in the tappets. Keep adjusting and checking until you get the .330 lift. It won't be nearly as much clearance as you think. I have a slight click at an idle when cold but it gets a little better when it warms up . Some of it due to strong valve springs, some due to cam profile and some due to the tappet clearance. I'm not changing anything though, it runs like a bear. I think the cam grinders are optimistic when they list them as .340 lift. thanks,,, and so far I have not been teched because the club i pull with has 1 "stock" class but the only limitations there is 4600rmp and tire size. how would i check to see if i have it adjusted to .330? Share this post Link to post Share on other sites
Jim_M 179 #10 Posted December 27, 2012 Put a dial indicator on the top of the valve with the valve seated, roll the engine forward until the valve is at maximum lift, set your tappet so the indicator reads .330, then roll the engine through a cycle and check it again. Do this to both valves, bolt the head on and go pulling. Share this post Link to post Share on other sites
Fast N Red 5 #11 Posted February 16, 2013 Put a dial indicator on the top of the valve with the valve seated, roll the engine forward until the valve is at maximum lift, set your tappet so the indicator reads .330, then roll the engine through a cycle and check it again. Do this to both valves, bolt the head on and go pulling. wont this make me suck avalve Share this post Link to post Share on other sites
