mike lynch 0 #1 Posted December 10, 2012 My friend Rick fendley in whitevale ontario canada has just acquired a WHEEL HORSE TRACTOR age is around the 1963--1968 era , he has been told by person who gave it too him. I have joined this forum on his behalf to find out information so he can rebuild it. We are not sure exactly what model he has . Somehow the model number of 10141 does not turn up on the web. Got this off the plate------ serial number-----166928 model 10141 transmission has tag says B-80 4 speed motor is a 1 cylinder Question.........i feel that in order to be able to purchase manuals and order parts for him , i need to have the correct model designation........ like b-81 ? or c-100 ? or ??? Can somebody direct me too the correct answers and where i should go to acquire parts and manuals. I can be contacted directly by email mike350 at rogers dot com thank you.......mike lynch----whitby ontario Canada Share this post Link to post Share on other sites
VinsRJ 723 #2 Posted December 10, 2012 Welcome to Red Square! Lots of great members will to help... Share this post Link to post Share on other sites
racinfool40 202 #3 Posted December 10, 2012 1st Welcome and by the model # 1-0141 it is a 1975 B-80 4-speed. Engine should be a Kohler K181s spec#30629D lets us know what ay need in the wanted..classified section and I'm sure someone will have what you need. MIKE Share this post Link to post Share on other sites
mike lynch 0 #4 Posted December 10, 2012 thanks guys , your help appreciated, will forward this info onto my friend Rick who owns the tractor. mike lynch Share this post Link to post Share on other sites
AMC RULES 37,144 #5 Posted December 10, 2012 Welcome to the both of you. Share this post Link to post Share on other sites
Wheelhorse84 87 #7 Posted December 10, 2012 Welcome Share this post Link to post Share on other sites
Sparky-(Admin) 22,006 #8 Posted December 10, 2012 :WRS: Mike......... Share this post Link to post Share on other sites
welderman85 53 #10 Posted December 11, 2012 Welcome Share this post Link to post Share on other sites
nylyon-(Admin) 7,444 #11 Posted December 11, 2012 Can somebody direct me too the correct answers and where i should go to acquire parts and manuals. First As far as parts and manuals Check the manuals tab at the top ^^ there you will find the parts manual as well as the owners manual for that tractor. For parts, check the links section or place a wanted ad right here on the forum. I am certain everything you / he needs for the tractor is right here on :rs: Share this post Link to post Share on other sites
KATO 115 #12 Posted December 11, 2012 Welcome to your one stop shop !!! Share this post Link to post Share on other sites
mike lynch 0 #13 Posted December 11, 2012 went to the manuals and printed out a couple of them that were for ricks tractor..model 1-0141 and model B-80 4 speed. Placed a wanted ad for a repair manual either original or a copy of. The rear end axles, the keys are toast and the key opening in the actual axle is opened way to much with wear, so if replacement axles cannot be found then new key ways will have to be cut on the axles opposite the old ones. Also will need the long headlight assembly , as this one is missing it. Other than that it seems in decent shape. mike lynch Share this post Link to post Share on other sites
Don1977 604 #14 Posted December 24, 2012 B-80's did not come with head lights just a block out plate. They may have been added as an option by the dealer. You can post that you need the axles in the Classified Section. You will probably need hubs too if the axles are that bad. Share this post Link to post Share on other sites
mike lynch 0 #15 Posted December 24, 2012 thank you on the plate info, will tell rick his tractor did not come with lights. The hubs actually are fine, the axles are rough in the key way area......he is going to see if he can get a machine shop to cut new openings and get new key way keys for it. mike lynch Share this post Link to post Share on other sites
varosd 1,185 #16 Posted December 24, 2012 :text-welcomeconfetti: :wwp: Share this post Link to post Share on other sites
KC9KAS 4,743 #17 Posted December 24, 2012 :WRS: And, :wwp: Share this post Link to post Share on other sites
Terry M-(Moderator) 2,203 #18 Posted December 25, 2012 Welcome to the :rs: Share this post Link to post Share on other sites
fabricator2009 48 #19 Posted December 29, 2012 welcome to red square. Share this post Link to post Share on other sites
can whlvr 993 #20 Posted January 7, 2013 welcome from a fellow canuck Share this post Link to post Share on other sites
JC 1965 1,532 #21 Posted January 8, 2013 Hi Mike, and :WRS: Share this post Link to post Share on other sites
mike lynch 0 #23 Posted January 10, 2013 Welcome to Red Square! Lots of great members will to help... Actually tried to post a wanted for B-80 4 speed axles 3 times and sytem kept spitting it back at me so gave up trying to post in the wanted section. I emailed admin and got zip in help. mike Share this post Link to post Share on other sites
tunahead72 2,515 #24 Posted January 13, 2013 Actually tried to post a wanted for B-80 4 speed axles 3 times and sytem kept spitting it back at me so gave up trying to post in the wanted section. I emailed admin and got zip in help. I can't explain why your ad isn't being accepted. I would try starting a thread in "site suggestions, updates, issues", you're more likely to get a response there. And :WRS: Share this post Link to post Share on other sites
mike lynch 0 #25 Posted January 13, 2013 I would have to try to post a wanted advert again and see exactly what the offensive wording was and write it down that would not allow me to post ad. Have sent the axles out to have new keyways cut on opposite side of axles. mike Share this post Link to post Share on other sites
