wallfish 17,412 #76 Posted March 21, 2013 That thing is comin' nice. Make sure to tighten the spark plug and put some gas in it for Mike's ride. Here's the story of his last adventure. Share this post Link to post Share on other sites
chris11 184 #77 Posted March 23, 2013 Hey Jeff how are the rear hubs coming?, I was thinking you could use wheelhorse rear hubs and just make a stepped down collar with key way in them. Share this post Link to post Share on other sites
fireman 1,022 #78 Posted March 23, 2013 Just got the metal yesterday for them. I should have them done by this up comming weekend. Share this post Link to post Share on other sites
chris11 184 #79 Posted March 24, 2013 I want to see that thing done, cant wait to see it with rear wheels on it.. my offer still stands if you need that broach it only takes 10 mins to do it in a press. Share this post Link to post Share on other sites
fireman 1,022 #80 Posted March 24, 2013 Checked with my friend the machinist and his wire EDM machine can do a 10" deep part. Mine are only 8" so I'm all set. He is also cutting me out some end plates and putting in the bolt pattern for me. Once I get the parts from him all I need to do is weld it all together! Share this post Link to post Share on other sites
chris11 184 #81 Posted June 12, 2013 Jeff any luck? love to see a picture all done. Share this post Link to post Share on other sites
fireman 1,022 #82 Posted July 28, 2013 I finally ordered the shaft couplers I needed and they came in on Friday. Started working on the tractor that night. Did some more yesterday. I ate breakfast this morning then went down to the shop and went gang busters at it. Got the rear hubs all welded up and mounted to the existing axles. Mounted the rear tires and rolled it off the lift. I had to grease the front bearings as they were new and I had put them on during fabrication for fit. Got those done and remounted then outside she went. The battery was weak from sitting all winter so I had to start it with the jump pack. She fired right up and runs great. It drives perfect and the shifter works good. The steering is surprisingly very easy. I am thrilled at the way it came out. Now to paint the metal I added, the rear-end and touch up anything else that needs it. Can't wait to bring it to the next tractor show!!! 3 Share this post Link to post Share on other sites
chris11 184 #83 Posted July 28, 2013 That is very cool Jeff, nice work man. I want to see that at the shows. Thanks for the pictures Share this post Link to post Share on other sites
Sparky-(Admin) 21,939 #84 Posted July 28, 2013 Looks great! Maybe it'll make it to Zagrays this fall ?? Mike.......... Share this post Link to post Share on other sites
fireman 1,022 #85 Posted July 28, 2013 I plan on being at Zagray in the fall and this will be there too! Share this post Link to post Share on other sites
SALTYWRIGHT 859 #86 Posted July 28, 2013 I WANT TO SEE IT ALSO...... Share this post Link to post Share on other sites
AMC RULES 37,144 #87 Posted July 28, 2013 I'd like to ride it... but I'm scared of heights. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,397 #88 Posted July 28, 2013 Looks good Jeff. Feel free to bring it over to the ponderosa for a ride around if you want. Share this post Link to post Share on other sites
fireman 1,022 #89 Posted July 28, 2013 Here is a short video. Share this post Link to post Share on other sites
fireman 1,022 #90 Posted September 7, 2013 Just and update. I didn't want to just trust the single set screw against the keystock to hold the hubs and tires onto the axle. So I drilled out one on the set screw holes in the hub that was located closer to the inner end of the axle. Then used a transfer punch to make a mark on the axle shaft. Removed the hub and drilled and tapped it for a 1/4-20 bolt. Now the hub is firmly bolted to the axle along with the original set screw and key stock. Here are two more pictures of the finished project. The second one has me in it so you can see a size comparison. Don't know if this is a far as I am going to take it. I may opt for a paint job and maybe some type of roll bar so I can put some lights on top! 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,397 #91 Posted September 7, 2013 If you put a roll bar on it you are gonna need a bigger enclosed trailer ! Looks good Jeff. Share this post Link to post Share on other sites
SALTYWRIGHT 859 #92 Posted September 7, 2013 JEFF WILL YOU BE AT KENT WITH IT ? Share this post Link to post Share on other sites
fireman 1,022 #93 Posted September 7, 2013 Hey Russ, Yes I will be at Kent on Saturday and it will be there too! Gonna go to Kent on Friday also just to get first dibs in the Flea Market section Share this post Link to post Share on other sites
Coadster32 793 #94 Posted September 9, 2013 Great job on it!! Looks awesome and seems like it handles pretty darn good. Have you done any off-roading with it yet to test out it's manners?? Share this post Link to post Share on other sites
Ken B 3,165 #95 Posted September 10, 2013 Looks great Jeff! (But,) I think you need to bust out another thousand and buy one of them Jeep body kits for it. I think you'd easily get your money back if you decide to sell it...Can't wait to see it at the Kent show. Share this post Link to post Share on other sites
