Amanda 81 #1 Posted November 22, 2012 Does anyone know of a good way to get the differential lock from sticking!?!? Share this post Link to post Share on other sites
AMC RULES 37,134 #2 Posted November 22, 2012 Unloading the diff, in reverse doesn't help? Share this post Link to post Share on other sites
Amanda 81 #3 Posted November 22, 2012 Yes I tried that and then my husband to double check lol and it didnt help Share this post Link to post Share on other sites
baerpath 517 #4 Posted November 22, 2012 Look down through the slot is the rod attached ? Follow the rod back to the trans spray it up with WD40, PD blaster what ever and work the rod back and forth. The high low and diff both seem to get stuck sometimes. I think it because they don't get used much. Do you have the manuals for yours? Duane Share this post Link to post Share on other sites
Amanda 81 #5 Posted November 22, 2012 its not the linkage belive its in the case Share this post Link to post Share on other sites
baerpath 517 #6 Posted November 22, 2012 If you follow the rod back on the right axle tube is where the dif lock is. All that holds it is a ball and detent in the shaft They sometimes get stuck nothing major. You may have to pull the axle and manually move the rod. I'd try working it loose from outside first On top of the tube over the rod is a bolt take it out carefully theres a spring under it spray it full of PB blaster and keep trying it. Usually they work free Share this post Link to post Share on other sites
baerpath 517 #7 Posted November 26, 2012 Did you get it fixed ?? Share this post Link to post Share on other sites
Amanda 81 #8 Posted November 26, 2012 No, we havent had anytime to tinker with it. Hopefully this weekend :( Share this post Link to post Share on other sites
