bmuone
Hydraulic control
bmuone
I have a c175 and I replaced the hydraulic hoses becuase of leaking problems. Now the control where the up down lever is, is leaking worse. The control on my unit has all four hoses coming from the bottom. I see other controls on ebay where there are two connections at the end and two on the bottom. Are these units interchangeable? And let me add I am NO hydraulic mechanic. First time experience and I lack to never have gotton the new hoses to all connect up and go back in the tight places because the mechanic that made them up used newer (bigger) connectors. Now back out they come. I will start searching for another one when I figure out which ones will work. Tks
Dayton
KC9KAS
Not sure on your specific problem, but I too had a heck of a time installing new hydraulic hoses on a GT-14 because of the larger fittings used on the hoses. :angry-screaming:
varosd
perhaps this old thread may help?
Amanda
i would assume so if they are off the same tractor, maybe if you take it apart and maybe rebuild?
