KEN NABER 28 #1 Posted November 15, 2012 Hello I am replacing coil and of course want to get new spark plug wire. The old wire is made of strands of wire real wire, suggestions on replacement appreciated. 1960 Suburban K91 4hp. Ken Share this post Link to post Share on other sites
KATO 115 #2 Posted November 15, 2012 That is old non suppression wire. We used it on performance engines occasionally at a place i worked in the 90's It may still be available from performance jobber's ???? But i would replace it with newer suppression wire because it wont interfere with radio recption ,TV and the likes. If its solid core wire dose it really need replacing ????? Share this post Link to post Share on other sites
305 380 #3 Posted November 15, 2012 i'd get some 7mm solid core wire and the appropriate ends from an auto parts store and make one. or you could just order part # 7-01700 from Primeline. Napa or O'Reilly should be able to get it for you Share this post Link to post Share on other sites
KEN NABER 28 #4 Posted November 15, 2012 the old wire is missing the plug terminal end and may be a little short, i wish it was ok Share this post Link to post Share on other sites
305 380 #5 Posted November 15, 2012 here is the Primeline coil wire Share this post Link to post Share on other sites
wallfish 16,980 #6 Posted November 15, 2012 You can replace the wire without changing the coil on a K91. Pull the wire out of the coil ( easier said than done) and you will see the little pin inside the hole that pokes into the wire. That's why a stranded wire would work better. Epoxy it back in. 1 Share this post Link to post Share on other sites
KEN NABER 28 #7 Posted November 15, 2012 thanks to all Share this post Link to post Share on other sites
groundhog47 347 #8 Posted November 16, 2012 You can replace the wire without changing the coil on a K91. Pull the wire out of the coil ( easier said than done) and you will see the little pin inside the hole that pokes into the wire. That's why a stranded wire would work better. Epoxy it back in. John, my K-241 is magneto under flywheel coil I presume similar to smaller engines do you know if the spark wire is removable and replaceable like that, thanks. Share this post Link to post Share on other sites
wallfish 16,980 #9 Posted November 16, 2012 I don't think so but I'm not sure. I only know the K91 coil wire can be done because I changed one. But.... If your coil is junk because the wire is junk, pull it out and see. If not, you needed to buy a new coil anyway Share this post Link to post Share on other sites
