coldone
D series Hydro motor reassemble vid Part1
coldone
Finally! I had a chance to get back out to the shop and get the hydro motor back together. I had taken apart in previous vid and I had to stop when it came time to press the shaft out. I tried getting it out without a press and i buggered up the locking mechanism. I got the parts to repair that and I start the reassembly of the motor.
In this vid i show how to install the locking mech, lapp the valve plate, lapp the cylinder block, the differenecs between a standard 15 series motor and the WH motors, and clean up a little.
This motor will work on the D series and C series.
I hope it helps a few people.
pfrederi
Great stuff!!
Where did you get the locking ring from? I have a couple with broken tabs
coldone
What locking ring? the spiral lock?
Trouty56
Coldone....was wondering where you have been. Great video.... I thought 43 minutes would be a long time but now I'm waiting for part II.... Thanks for the time that you have put into this topic....
pfrederi
The spring clip that goes on the shaft, you mention it at the end of the video...somewhat pricey you said.
What was the source??
coldone
LJ fluid power in MI. (269) 623-4150
You will need to talk to LJ and have the wheelhorse part numbers. I thin the clip was $15.
coldone
Part II will get uploaded tonight while I sleep (4hrs to upload). It will cover the locking mechanism, I put it together wrong the first time, and the rest of the assembly. I get it all back together except fo rthe accel valves. I want to do a vid of them disassembled and cleaned.
After that I will be working on a series for the pump. My orginal has some issues so I bought one from Joes OPE that has stripped splines.
I know that the vids are long and I havent taken the time to edit them for lenght. I really just wanted to get the info out and as much of it as I could. There just wasnt any decent vids or manuals showing what's in the motors and pumps. My motivation was seeing all the D series adds (CL) and posts about how the tractors wouldnt go up a hill and people were just getting rid of them or passing them up. Hopefully now we (GT nuts) can save a few more from the scrap pile. Hopefully a few more people will pick up some cheap Ds and spend a little time on the hydro system and have a great tough tractor afterwards.
JamesBe1
Excellent video my friend. At first I though that 43 minutes would be painful to sit through, but I was way wrong. I downloaded it to save on my computer to watch when I get up the courage to attempt it myself.
Can't wait for part II.
Thanx for doing this for the rest of the community and the dysfunctional D family!
pfrederi
Thanks so much for the info and the great video.
The D is getting her pump and motor replaced this winter.
coldone
If you are using used parts,take them apart and clean and inspect them. The best practice will be to break apart the transaxle too and clean it out while you are there. If there is any metal shavings in the system after you change out the pump and motor, it will damage them. Dont forget to flush the manifold lines too.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
