smoreau 658 #26 Posted November 14, 2012 Next you should ad power steering sense your not using the lift cylinder the 520 originally come with. Don't want to ad more woke for you, but it would help a great deal. find a fork truck salvage yard, most come with a steering valve you can get cheep! and just ad the correct cylinder. I picked up my last valve for $20 and ended up selling if for some quick $ for $100 Now I could use it for my loader project. Share this post Link to post Share on other sites
dbartlett1958 99 #27 Posted November 17, 2012 Joe, I picked up a set of those same front tires recently for my 416-H. Makes a huge difference with the snowblower on. I may have to do some adjusting next spring when the mower deck goes back on, but I will deal with that then. Nice looking job and excellent work on the tractor and loader. David Share this post Link to post Share on other sites
boatman 3 #28 Posted November 29, 2012 That 520 sure came out nice and you did a great job on loader too. I built one for a GT-14 and use it all the time. They sure save the back alot. great job. Share this post Link to post Share on other sites
JoeM 8,521 #29 Posted December 8, 2012 I had a few questions about the subframe and pump mounting, The frame is straight 1 1/2 square tube 15 3/8 wide. The pump bracket is 11" tall x 4 wide. The pump swivels on the rear bolt and the front bolt is slotted. The belt is an A27 (29"). I added two angle clips in frame as a precaution. One of these can be seen in the background of the frist picture. 1 Share this post Link to post Share on other sites
Dieselcowboy 210 #30 Posted December 8, 2012 Thank you for posting those pics. Really going to help me jump start my project. Share this post Link to post Share on other sites
carbonx 0 #31 Posted February 26, 2013 Nice loader joe, this is Original Allis Chalmers loader need you hand. thanks Share this post Link to post Share on other sites
myron in ct 2 #32 Posted February 27, 2013 Hi Oiluj52 You are real craftsman . I wish could what you do. I have a 520 to put a loader on but don't have the under carriage . Will you please give the dimension and tubing size . I know it is pain but really need help . Myron in ct. Share this post Link to post Share on other sites
cschannuth 3,817 #33 Posted December 29, 2017 On 11/12/2012 at 3:46 AM, OILUJ52 said: Picked up this old 520H in Ohio. She was pretty rough. The plan was to clean up and make a mini loader to use around the yard. I have a D series loader that works pretty well but it is just too big. After a bath, tuning, some sand blast and paint, It started to look good. Installed a Matt860 Hydro pedal kit, upgraded the front axles to 1", new tries, weights, and used plans from PF engineering as the starting point for the loader. I modified the plan to have more bucket roll back when in the lower positon. (This does sacrifice the dump side at the raised position), I found a happy medium between the two without fancy linkage. I still have some fine tuning, the hydraulics are way too fast, at least on the boom lower. Looking into a flow control now. Thanks for looking, Joe You wouldn't happen to have any pics of this fine machine from the side with the bucket sitting flat on the ground? I'm having a few clearance issues with the PF plan and want to see how yours fits together. My arms are too close to my front tires due to the front swept axle and the oversized front tires I'm using. Thanks, Craig Share this post Link to post Share on other sites
JoeM 8,521 #34 Posted December 29, 2017 (edited) Yep, I have a sketch on my home computer, I send it to you this afternoon when I get home Joe Hope these pictures help. These are the ones from the swept forward axle. Edited December 29, 2017 by OILUJ52 Share this post Link to post Share on other sites
