JoeM 7,874 #1 Posted November 12, 2012 Picked up this old 520H in Ohio. She was pretty rough. The plan was to clean up and make a mini loader to use around the yard. I have a D series loader that works pretty well but it is just too big. After a bath, tuning, some sand blast and paint, It started to look good. Installed a Matt860 Hydro pedal kit, upgraded the front axles to 1", new tries, weights, and used plans from PF engineering as the starting point for the loader. I modified the plan to have more bucket roll back when in the lower positon. (This does sacrifice the dump side at the raised position), I found a happy medium between the two without fancy linkage. I still have some fine tuning, the hydraulics are way too fast, at least on the boom lower. Looking into a flow control now. Thanks for looking, Joe 13 1 Share this post Link to post Share on other sites
jay in nc 210 #2 Posted November 12, 2012 my you do nice work , nice save on an abused tractor! Jay Share this post Link to post Share on other sites
KC9KAS 4,741 #3 Posted November 12, 2012 Very nice looking tractor and loader. :text-coolphotos: Share this post Link to post Share on other sites
Wheelhorse84 87 #4 Posted November 12, 2012 Looks great. Share this post Link to post Share on other sites
posifour11 723 #5 Posted November 12, 2012 Very well done and a clean install. I like it. What are the specs for the hydraulic system? Share this post Link to post Share on other sites
dclarke 4,046 #6 Posted November 12, 2012 Nice job on the loader, it looks like a factory build. :thumbs: Share this post Link to post Share on other sites
Jim_M 178 #7 Posted November 12, 2012 Nice job. I have a similar setup, I think you'll find that you need about 4 times more weight on the rear. Share this post Link to post Share on other sites
Ken B 3,164 #8 Posted November 12, 2012 That 520 has come a looooonnnnggg way. You did a fantastic job bringing her back, not too mention that is some pretty nice fab work on that loader. Share this post Link to post Share on other sites
AMC RULES 37,141 #9 Posted November 12, 2012 Looks really good...where did you find the front hubs and axles? Share this post Link to post Share on other sites
wallfish 17,112 #10 Posted November 12, 2012 Very nice. That's a great idea to roll the bucket a little farther back. I need to modify mine to do that since the material is always spilling out when the bucket is full. Share this post Link to post Share on other sites
JoeM 7,874 #11 Posted November 12, 2012 Thanks for all the feedback! The hydraulic pump came from Northern item number 10567 .517cu, 4 gpm @ 1800rpm and 8 @ 3600. Would be good if I was installing a back hoe, too much for just the loader. I should have used item number 1002965 .094 Cu. 1.5 gpm @ 1800 and 3 gpm @ 3600. the relief is set at 2000psi but I am going to adjust it down, maybe 1200? This may keep my son out of trouble when he uses the machine. The front hubs, I believe, are also Northern item number 57204. One inch front axles are 520H from e bay, (lucked out and bought these right). 10-4 on the extra weight got steel plates coming that will bolt on to the rear tank area. Share this post Link to post Share on other sites
wallfish 17,112 #12 Posted November 12, 2012 I used the same pump for my hoe and it is fast but once I got used to it, everything is good. The slew cylinder (side to side) is the only one that may need to have a flow control. It's a bit dangerous during the occasional miscue. Share this post Link to post Share on other sites
HorseFixer 2,012 #13 Posted November 12, 2012 WoW oilu52 yep you Resurected this one back from the PITS OF HELL! My hats off to ya pal I love craftsmanship and you delivered big time. Hmmmm........ I do have a spare 520 Ya got me ta thinking. Keep up the Good Work, ~Duke Share this post Link to post Share on other sites
MalMac 1,332 #14 Posted November 12, 2012 Nice life saving on the 520, really nice loader that's one to be proud of. wish I could tear down my Ark and redo it but it is in constant use. You will probably find the same thing, always using the loader for something big or small jobs. Share this post Link to post Share on other sites
312Hydro 474 #15 Posted November 12, 2012 Very nice fab work on the FEL and a great job on the 520H too. :handgestures-thumbupright: Share this post Link to post Share on other sites
Stigian 1,234 #16 Posted November 12, 2012 Wow Joe.. Some great work there.. Your FEL looks very heavy duty :handgestures-thumbup: Share this post Link to post Share on other sites
gcole 36 #17 Posted November 12, 2012 Great job on the tractor and loader Share this post Link to post Share on other sites
smoreau 658 #18 Posted November 12, 2012 Nice looking foot control on that 520! How well does it work! looks like a modified Matt set up. Loader looks great!! :handgestures-thumbupright: Share this post Link to post Share on other sites
JoeM 7,874 #19 Posted November 13, 2012 Yep, I purchase the stuff from Matt less the pedal. I fabed the pedal assy. Works pretty good. I did replace the steel bushing piece that slides in the "birds mouth" with a bearing and that made a great deal of difference. So far so good. Thanks to all the positive feed back! Share this post Link to post Share on other sites
JackC 617 #20 Posted November 13, 2012 Must be nice to be able to make what you want. Very nice piece of work. Share this post Link to post Share on other sites
tiggercl 28 #21 Posted November 13, 2012 Just out of interest what is the most appropriate style of front tyre when a loader is installed (ease of steering, minimal turf damage etc.) ? Share this post Link to post Share on other sites
posifour11 723 #22 Posted November 13, 2012 What sizes are your cylinders? I've always wondered what the right size and stroke would be. Share this post Link to post Share on other sites
Ken B 3,164 #23 Posted November 13, 2012 Just out of interest what is the most appropriate style of front tyre when a loader is installed (ease of steering, minimal turf damage etc.) ? I think a set of tri ribs would be best myself. 1 Share this post Link to post Share on other sites
JoeM 7,874 #24 Posted November 13, 2012 Cylider size for this machine is 14" stroke maxim #288-305. The tires I used are trailer tires. Wanted to make sure they could handle a load. Got them at etrailer.com, part number am3h200. Something to think about when selectiong loader tires is first the load rating, I like 2 x safety factor per tire, next footprint, on soft ground wider is better, but steering gets tougher the wider you go. Share this post Link to post Share on other sites
HorseFixer 2,012 #25 Posted November 14, 2012 Just out of interest what is the most appropriate style of front tyre when a loader is installed (ease of steering, minimal turf damage etc.) ? I think a set of tri ribs would be best myself. Yer Right! :handgestures-thumbupright: Share this post Link to post Share on other sites
