NF-Tinman 2 #1 Posted November 7, 2012 I have a rear seal leaking on the rear axle of my 1992 520H Wheelhorse. I want to remove the entire rear end from the tractor and replace all the seals, since I have to do one i may as well do them all. Can some one out there lend me a little guidance or advise to make this job a little easier, or is it just as well to leave the entire rear end in place and replace the seals that way? If so what is the best way to go about replacing the seals? Thanks in advance. 1 Share this post Link to post Share on other sites
Trouty56 567 #2 Posted November 7, 2012 Personally since you don't have to remove the tranny to replace the axle seal I would only replace the one that leaks. It is a quick job. I don't know what other seals there are but unless you have to remove the tranny on a hydro I think you best leave it alone. There are a few how-to's if you search a little.....get the hub off......pick the seal out..... emery cloth the axle to remove barbs and smooth the surface......clean the axle/seat area.......tape the axle from the inside out......oil it up good and slide the new seal on......tap in place with an appropriately sized PVC pipe. This is just a summary. 2 Share this post Link to post Share on other sites
Kelly 1,030 #3 Posted November 7, 2012 I would replace the axle seals, both sides and leave the rest alone, not very often the other seals leak on the Eaton 1100 1 Share this post Link to post Share on other sites
NF-Tinman 2 #4 Posted November 7, 2012 Thanks for the info. Share this post Link to post Share on other sites
chex313 123 #5 Posted May 16, 2020 Does anyone have an online seller for the seal? Share this post Link to post Share on other sites
stevasaurus 23,065 #6 Posted May 16, 2020 chex...do you have the Eaton1100 transmission??? 1 Share this post Link to post Share on other sites
chex313 123 #7 Posted May 16, 2020 (edited) 1 hour ago, stevasaurus said: chex...do you have the Eaton1100 transmission??? Yes '92 520H...Same as the OP Is it #3? from the schematic in link. https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/toro/riding-products/73520-520-h-garden-tractor-1994-sn-4900001-4999999/transmission-eaton-1100-032 Edited May 16, 2020 by chex313 Share this post Link to post Share on other sites
peter lena 9,088 #8 Posted May 16, 2020 these packing pullers ,https://www.grainger.com/product/4VLV4?gclid=Cj0KCQjwnv71BRCOARIsAIkxW9Fd3Qfd7N2w8xI36gP2kQkEB2iwpe840UfzxQJHzUzYPjZkU5KiaC8aArEzEALw_wcB&cm_mmc=PPC:+Google+PLA&ef_id=Cj0KCQjwnv71BRCOARIsAIkxW9Fd3Qfd7N2w8xI36gP2kQkEB2iwpe840UfzxQJHzUzYPjZkU5KiaC8aArEzEALw_wcB:G:s&s_kwcid=AL!2966!3!402208053119!!!g!469900349466! make seal removal easy , shop around to find one . drill a small hole in seal metal diameter , screw in and pull out. used to repack many tank seal drives , pete 1 Share this post Link to post Share on other sites
stevasaurus 23,065 #9 Posted May 16, 2020 @pfrederi, @formariz any of you guys have a cross reference to this seal?? I do not. 1 Share this post Link to post Share on other sites
pfrederi 18,332 #10 Posted May 16, 2020 Too new for me sorry 1 Share this post Link to post Share on other sites
chex313 123 #11 Posted May 16, 2020 (edited) Thanks for the replies, I think I have everything I need to get it out. Just want to have the right part before I pull the hub...I am not in any hurry, wanted to do this while I was waiting on other parts. I retire in June and finally have time for a spare project. Plus socializing in tractor forums is about the only socializing i am doing right now... Edited May 16, 2020 by chex313 Share this post Link to post Share on other sites
Trouty56 567 #12 Posted May 16, 2020 (edited) think the axle seal is number 1 on this https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/toro/riding-products/73520-520-h-garden-tractor-1994-sn-4900001-4999999/transaxle Looks like a typical seal.... Edited May 16, 2020 by Trouty56 1 Share this post Link to post Share on other sites
Trouty56 567 #13 Posted May 16, 2020 seal 6449 crosses to CR11124 1 1 Share this post Link to post Share on other sites
chex313 123 #14 Posted May 16, 2020 47 minutes ago, Trouty56 said: seal 6449 crosses to CR11124 Just found it here on the site in the Vendors section 47 minutes ago, Trouty56 said: 1 Share this post Link to post Share on other sites
