ray
belt guides from 1/4" rod
ray
I saw that someone posted about making belt guides to be use when the belt guard is missing, but the link isn't right and talks about painting parts. Doing a search for belt gides here takes me to where the link is posted that links to painting parts. Any help in this department?
rmaynard
Many of the links were screwed up when the forum moved.
See who the author of the original post was and PM them directly to see if you can get more info.
Callen
There is some pics of homemade guides in the Transmission section under 551 clutch problems.
wallfish
Here's the 551 thread with pics. You should only need two, 1 above and 1 below the engine pulley
