rmaynard
Removing lift arm from a 701
rmaynard
I've read several posts on the subject, and I was warned that trying to remove the lift arm from a 701 would try my patients, but I really didn't realize how true that was. :banghead: I have struggled with stuck wheel hubs in the past, but this is quite the task. I have the roll pin removed, and I have been soaking the assembled pieces in PB Blaster, but as of yet, there is no movement. I don't want to mushroom the end of the shaft by beating it with a hammer, and I don't see any way to use a puller. The entire assembly and hood stand is off the tractor.
Any help from anyone who has removed one of these (without damage) would be appreciated. :thanks:
Kelly
HEAT lots of it, and a air hammer with a blunt tip I've taken a few out that way with no bigg issues, but some I've had to heat a few times, and I mean red hot.
dclarke
Bob, I had to heat mine to get it out.... They can be a real pain, that's for sure.
squonk
Get yourself a good brass punch. If you have to wack it, The punch gets abused and not the part.
sorekiwi
Yup, what they all said!
On my 502 propane wasnt enough, needed oxy/acetylene and the center bit red hot. You need to be careful that all your beating doesnt distort the hoodstand too much.
Good luck!!.
rmaynard
Looks like I'm going to have to turn up the heat.
Thanks gentlemen!
AMC RULES
Wonder...would you document for us, what the process entails Bob? :text-feedback::wwp::text-thankyoublue:
rmaynard
I have tried heating with propane, which is all that I have. Since it looks like I will have to take it somewhere to have access to acetylene I may not be able to document with pictures. I will do a follow-up though and let you know whether or not I was successful.
stevebo
Put it back together and keep it original- lol :teasing-neener:
rmaynard
Steve, you know me. I can't leave them alone. Now that it's apart, it's not going back together unless it looks like it just came off the showroom floor.
AMC RULES
I was just thinking...
if anyone could discover a way to make it easier for the rest of us to do, it would be you Bob. :bow-blue:
rmaynard
Well, here it is almost 3 months since I began this task. The lift arm assembly has been soaking in PB Blaster the entire time. I finally got a day off and decided that I would not sleep until the lift are was removed. So, I got out my brass punch and began to punch. No movement. I visited a friend with a large vise and an acetylene torch. We clamped the lift in the vise and heated it until it glowed orange. I could then rotate the arm slightly, but it would not move to the side. Again we pounded on it with the brass punch until it was flush with the outside of the dash tower. At that point, we decided to get out the impact driver. That only succeeded in mushrooming the end of the shaft and keeping it from going through the lift portion. So we got out the grinder and ground off the mushroomed end, and continued to use the impact driver until the shaft had moved about 3/4" and stopped. At this point, all we were doing was concaving the end of the shaft inside the lift mechanism, causing it to further restrict movement. With the 3/4" gap now between the lift arm and the tower, we managed to fabricated a method of holding it on the 40 ton press. By golly, after about two hours total, we had it apart with minimal damage to the sheet metal.
That is a project that I don't wish on anyone. Considering how easy everything else has come apart on this 701, I was really surprised at the difficulty level this was.
Martin
sometimes its the smaller stuff that you spend the most time on. at least you finally got it apart. when you fight forever and still end up losing, resulting in cutting the shaft or whatever is the easiest part to replace thats when its hard to take,
steering wheels and lift arms seem to be right up there with the best of them as far as pain in the a## things to do sometimes..........
congrats on winning the battle, bob!!
rmaynard
Though I never plan to take it apart again after it is reassembled, I am going to liberally coat the shaft with never-seize. Who knows, 52 years from now, maybe my grandson or great-grandson might decide to take it apart again. He will thank me and say,
  • Like 4
jay in nc
i'm looking forward to seeing it as the featured tractor in june. your restorations are top shelf Bob.. Jay
buckrancher
yea originally rusted
Butch
Go to Home Depot, Lowes or your Hardware store and get the yellow can. I think it may be acetelyn but I'm not sure. It's a whole lot better than that propane you're using. I don't even mess with the blue cans anymore.
  • Similar Content
    • buzzard440
      By buzzard440
      1961 701 for sale complete and original w/ mower deck. Runs but needs TLC.
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
