Rollerman
D250 questions
sparky6398
Thanks, that's great info on my machine.
56flatbed
Nice pic of a restored DS2500 on the Gutbrod website, but the driver is on the hood. :eusa-whistle:
Wally
C-101plowerpower
Wally
you mean this one?
Koen
brandonozz
Now that is one sexy tractor!
N2 Tractors
On 1/11/2014 at 3:06 PM, C-101plowerpower said:
since the d250's are pretty much the same as gutbrod 2500, parts can be found in germany
http://gutbrod-schrauber.de/ersatzteile-f-r-2500-s.html  (Bad Link)
http://ersatzteilhandel.jimdo.com/gutbrod-2500-getriebe/ if you open the pdf on that site you'll get an exploded view of the transmission (Bad Link)
http://ardiehl.de/Gutbrod/Gutbrod_2500_Benzin_Motor.pdf engine pdf
hope this helps
Koen
On 1/14/2014 at 1:01 AM, C-101plowerpower said:
The last two links are great for part numbers.  Thank you very much.  I need a starter and a water pump for my D250 with Ark 550 FEL and ARPS Box Blade set up.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
