slufoot733
Wheel weights for D-200
slufoot733
Am thinking of making my own wheel weights for my 1978 D-200. Anyone ever make your own weights? First thought is to cast them out of concrete in a round mould with PVC pipe running through for mounting bolts. Any suggestions, ideas, direction or info would be greatly appreciated.
KC9KAS
Several folks on here have made their own wheel weights, and concrete has been one of the materials used.
Go to the SEARCH box, type in wheel weights and see what others have made.
1maidenfan
Some pix of your horse set up would be nice ! Thanks
Trouty56
Could always fill those big tires with beet juice or RV antifreeze. I think you can get 7 gallons in a 26X12X12 tire. 56 lbs of the RV stuff and 65-70 of the beet juice. I use weight on the 3 pt myself.
slufoot733
I used to have windshield fluid in both tires but one started leaking. Ended up removing both tires and installing tubes to hold air. Now I can't add fluid cause if I let the air out the valve stem dissappears into the wheel. Then the only way to get to it is break the bead and start all over. I liked the weight but it rusted the wheels something terrible. I'm lucky I was able to save them. Now I think wheel weights would be my best course. But thanks anyway.
Oh, and here's a pic or two of my D.
post-3323-0-01477700-1350271438_thumb.jp
post-3323-0-81908100-1350271480_thumb.jp
KC9KAS
Not trying to be a "smart a$$", but if the valve stem pulls into the wheel when you remove the air, you must have the tube in backwards, or the wrong size tube.
I bought a small valve that attaches to the valve stem that is used to pump fluid into the tires. It has a "burp" valve on it so you can let the air out of the tire/tube when installing fluid.
By the way, nice looking D with the snow-blower.
Stigian
I found zip ties were and still are just the job for stopping "vanishing valve stem" syndrome.. Not high tech but they have been getting the job done on my 312 for many years..
Tankman
Concrete and brake drums, works. Find drums at the junk yard to fit your rims.
Nice lookin' D series Horse!
slufoot733
I appreciate the kudos and advice. The tubes were installed by my local tire guy and they are the right size. Problem is the WH wheels used on the D series have the valve hole way over at the edge of the rim, not close to the middle where the valve on the tube is. When full of air it works fine but if the air leaks out the tube shrinks and sucks the valve inside. That being said I like that valve attachment with the burp valve. Where did you find those? And the brake drum idea is cool too. If I use both then I'll be super heavy! Or either one would be great.
KC9KAS
The "burp" valve I posted WAS NOT the one I bought, but is very close to being the same.
I got mine at a NAPA parts store.
.5racer
How do you like the blower ?
slufoot733
I enjoy using the snow thrower. It's a single stage so it has some drawbacks. But it can do a very good job if I don't move into the snow too quickly. Here's a video of me using it right after I got it assembled.
I haven't had a chance to use it in a really deep snow but I'm sure it will handle deep snow better than my JD with a snow blade. Word is we will have "more snow than average this winter" so I'm ready!
  • Heart 1
sadixon49
I'm very interested in this myself, but when I typed wheel weights into the search box all I got was this thread, which tells me to type wheel weights into the search box. I feel like I'm gong around in circles.
steve
KC9KAS
Type in homemade wheel weights and where it says "this topic" click on it and you will get a drop-down box....click forums and then search....I got 16 different threads. You were just searching in this thread
sadixon49
Thanks, that did it :)
steve
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
