FreddieFarmall 1 #1 Posted October 9, 2012 We just started working on a puller for my son. I purchased a nice 'rolling chassis' Commando 800 at the show in Arendtsville this summer. This model has 10" rear tires on a unique flat wheel with smaller diameter center hole, and corresponding 'boss' on the hub for the wheel to fit onto. I did not notice this until I put a set of 12" wheels on it. The bolt pattern fits, but the center hole is about 1/2 in larger, so wheel will only be supported by the lugs. Thought about trying to get another set of hubs, but this model has 1" axles. Any ideas? Thanks, Fred P. Share this post Link to post Share on other sites
AMC RULES 37,144 #2 Posted October 9, 2012 Post a pict if you can, so we can see what you're working with. Share this post Link to post Share on other sites
Sparky-(Admin) 21,863 #3 Posted October 9, 2012 No picture needed. Just get a set of 1" hubs off a 300 series machine and away you go. I think the 300 series machines have the twin set screw hubs. Or better yet (since your building a puller) get an 8 speed tranny with the 1 1/8" rear axles/hubs and retrofit it to your machine. It'll probably hold up better for pulling competitions. Mike............ Share this post Link to post Share on other sites
FreddieFarmall 1 #4 Posted October 10, 2012 Thanks Sparky- I will see what I can scare up. My son is 7 yrs old, and has been running one of his grandfather's tractors this summer. He is anxious to get this one going. I think he will probably not pull this one in more than 700 or 800 lb class, so I hope the orig. transaxle will hold up. I will post some pics of the progress Fred Share this post Link to post Share on other sites
Jim_M 179 #5 Posted October 10, 2012 If the lugs are tight, you'll be fine, it's all the support you need. 1 Share this post Link to post Share on other sites
kpinnc 13,443 #6 Posted October 24, 2012 Does the Commando 800 tranny have the extra-long 1-inch axles to go with those 10-inch wheels? I know my 8 4 speed has them, and I personally would not place too much strain on those axles for sure. 700-800 lbs class probably won't break them, but it's hard to say with all that added leverage of those long axles. Even a standard 4-speed tranny would be far stronger with 12-inch wheels. I agree with Mike: Try to locate an 8-speed with 1 and 1/8th axles. I apologize for nitpicking your plan, as it is done with the best intentions. I only do so out of concern for your son- because I would imagine it could get dangerous if he lost an entire rear wheel during the pull. Share this post Link to post Share on other sites
Wishin4a416 2,191 #7 Posted October 26, 2012 No picture needed. Just get a set of 1" hubs off a 300 series machine and away you go. I think the 300 series machines have the twin set screw hubs. Or better yet (since your building a puller) get an 8 speed tranny with the 1 1/8" rear axles/hubs and retrofit it to your machine. It'll probably hold up better for pulling competitions. Mike............ When did the 300 series go to 1 inch, or I guess I mean when did they go to the 1 1/8 axles. My 87 312-8 has the bigger axles. Share this post Link to post Share on other sites
FreddieFarmall 1 #8 Posted November 4, 2012 The transmission on my tractor does have those 'long' axles and you are probably correct that they won't hold up under a lot of weight. I will try to find a more durable transmission, but for the time being, I think this one will work OK. Will another transmission be a direct 'bolt on' switch or will I have to fabricate stuff? Fred Share this post Link to post Share on other sites
