WHorse1054 2 #1 Posted October 3, 2012 how do you make a set of duals? pic would help. thanks :scratchead: Share this post Link to post Share on other sites
Jake Kuhn 1,579 #2 Posted October 3, 2012 for mine, I don't do anything fancy, someone will probably post a pic of what the original adapters look like. Where there are the 4 holes in your rims I get some black pipe and cut it to the length that I would like, then just run some carriage bolts through there. Pretty simple thing to do. Jake Share this post Link to post Share on other sites
can whlvr 993 #3 Posted October 3, 2012 i made a set with 1/4 plate and some black iron pipe,i welded the plate inbetween the pipe on the distance that the 4 square holes in the rim heres a pic of the adapter without the duals,and a pic with duals Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted October 3, 2012 The factory setup (from the gallery): There is a dimensioned drawing floating around on the web somewhere. Miller tire also sells a kit which is basically a pvc ring to space the wheels apart and some carriage bolts. A lot of people have used it and say it works great. Share this post Link to post Share on other sites
AMC RULES 37,145 #5 Posted October 3, 2012 Here's a dual adaptor sitting on top of the stacked tires. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #6 Posted October 3, 2012 It's not easy to see, but I used three Sears wheel weights per side as spacers for the duals on my 704: A "borrowed" picture of the weights: 1 Share this post Link to post Share on other sites
Ed Kennell 40,468 #7 Posted October 3, 2012 I used four 1/2" threaded rods, the bottom of a 5 gallon bucket, and a bag of concrete mix. Use the wheels as a template to drill the 4 holes in the bucket and as a jig to position the rods while pouring the concrete. Dbl nut both sides of each wheel. Wts. are 35 - 40 lbs. Mine have been working for a year with no problems. 6 Share this post Link to post Share on other sites
546cowboy 301 #8 Posted October 3, 2012 Now that's a great idea for those spacers and you get wheel weights too! :eusa-think: Share this post Link to post Share on other sites
Ed Kennell 40,468 #9 Posted October 5, 2012 Now that's a great idea for those spacers and you get wheel weights too! And cheap....~ 12$ in material. I have now cut the rods and added a 1/2" connecting nut so I can run single or dual wheels and leave the weight on for both setups w/o having the rods sticking out when using the single wheel setup. I take the duals off in the winter to blow snow. Share this post Link to post Share on other sites
