krazy_horse 59 #1 Posted September 16, 2012 Is there any good tutorials with pictures (that I cant seem to find) on rebuilding Techy carbs? I want to remove those little freeze plug looking things and really do a first class rebuild. Thanks! 1 Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted September 16, 2012 I dont think I've ever seen anything other than what is in the manual. There are some pictures there showing the freeze plug removal. Good luck! Share this post Link to post Share on other sites
Terry M-(Moderator) 2,175 #4 Posted September 16, 2012 I would be interested in this info also because those tecumsehs are in everything I own. :) Share this post Link to post Share on other sites
pfrederi 17,640 #5 Posted September 16, 2012 Have never had to remove the plugs yet . Have tecumsehs on my L-107, Troybilt tiller, yard man snow blower, yard man chipper, sears weed wacker. Clean them good and they work fine. Share this post Link to post Share on other sites
krazy_horse 59 #6 Posted September 17, 2012 Thanks for the reply. The reason I mentioned the welch plugs is they are included in every kit I have looked at. I dont know if you need to remove them to get a really good cleaning. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,175 #7 Posted September 17, 2012 Thanks for the reply. The reason I mentioned the welch plugs is they are included in every kit I have looked at. I dont know if you need to remove them to get a really good cleaning. But this makes me wonder why those are included. do they sometimes wear-out or fall out or leak, or is it for replacement after a total dismantel and clean??? I'm going try a rebuild without the removel. Thanks Share this post Link to post Share on other sites
SousaKerry 501 #8 Posted September 17, 2012 I never used to remove them until I tried it one day. They are easy and I do it every time now. Pound a small screwdriver through the center of the.plug and pry it out. To insert place it in the hole and use a flat ended punch just smaller then the diameter of the plug. Tap the punch with a hammer and wallah. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,175 #9 Posted September 17, 2012 Thanks, Sounds easy enough for me to try. :tools-wrench: Share this post Link to post Share on other sites
krazy_horse 59 #10 Posted September 18, 2012 Yes,it is easy. I have a carb in soak this morning. This will be my best rebuild on these Tecky carbs. Thanks to all fo replys and advice! Share this post Link to post Share on other sites
VinsRJ 721 #11 Posted September 18, 2012 I suggest throwing the Tech carb out and replacing it with a Carter N. :happy-jumpeveryone: Share this post Link to post Share on other sites
Eboy 38 #12 Posted September 18, 2012 go on youtube. There are videos showing you how to re-build carbs. Share this post Link to post Share on other sites
Don1977 604 #13 Posted September 18, 2012 I suggest throwing the Tech carb out and replacing it with a Carter N. With a Kohler engine attached to the Carter N. :handgestures-thumbup: 1 Share this post Link to post Share on other sites
Buckshot 1 15 #14 Posted September 19, 2012 :) I used a small chisel ground on the end with a 45 degree angle. Do not forget to use finger nail polish to seal the outside edges of the welch plugs after installing. :flags-usa: Share this post Link to post Share on other sites
SousaKerry 501 #15 Posted September 19, 2012 Do not forget to use finger nail polish to seal the outside edges of the welch plugs after installing Doh.... I have never done that yet but now I'm going to start. Share this post Link to post Share on other sites
Buckshot 1 15 #16 Posted September 20, 2012 :) I should have added to my post, use colored polish as for some unknow reason gasoline will eat the clear polish but not the colored. This is a old trick used by old time mechanics/techs. Everyone used a different color of polish so the next time some one different worked on the carb., they would know by the color who worked on it before. :flags-usa: Share this post Link to post Share on other sites
buckrancher 2,679 #17 Posted September 21, 2012 besure the metal rod inside the tube next to the venturi (main jet) rattles back and forth if you shake the carb body next to your ear Brian Share this post Link to post Share on other sites
Terry M-(Moderator) 2,175 #18 Posted September 21, 2012 besure the metal rod inside the tube next to the venturi (main jet) rattles back and forth if you shake the carb body next to your ear Brian Yes,it is easy. I have a carb in soak this morning. This will be my best rebuild on these Tecky carbs. Thanks to all fo replys and advice! Thanks Brian, good to know. Krazy horse, what do people use these days to soak their carbs during a rebuild? 20 years ago I used laquer thinner. just had to make sure that all plastic and rubber was taken off. Share this post Link to post Share on other sites
pfrederi 17,640 #19 Posted September 21, 2012 besure the metal rod inside the tube next to the venturi (main jet) rattles back and forth if you shake the carb body next to your ear Brian Yes,it is easy. I have a carb in soak this morning. This will be my best rebuild on these Tecky carbs. Thanks to all fo replys and advice! Thanks Brian, good to know. Krazy horse, what do people use these days to soak their carbs during a rebuild? 20 years ago I used laquer thinner. just had to make sure that all plastic and rubber was taken off. I have had good success with Berryman's. Comes in a 1 gallon can with a basket inside. Les than $20 at Walmart, PEP boys etc. Share this post Link to post Share on other sites
krazy_horse 59 #20 Posted September 21, 2012 I dont remember the name,I bought the gallon can with the basket. I believe it is the Gunk Brand. I use to like the good stuff we got back in the old days that would eat your fingernails off., like a lot of things those days and good carb cleaner are gone forever. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,175 #21 Posted September 27, 2012 besure the metal rod inside the tube next to the venturi (main jet) rattles back and forth if you shake the carb body next to your ear Brian Yes,it is easy. I have a carb in soak this morning. This will be my best rebuild on these Tecky carbs. Thanks to all fo replys and advice! Thanks Brian, good to know. Krazy horse, what do people use these days to soak their carbs during a rebuild? 20 years ago I used laquer thinner. just had to make sure that all plastic and rubber was taken off. I have had good success with Berryman's. Comes in a 1 gallon can with a basket inside. Les than $20 at Walmart, PEP boys etc. Thanks, I'll look for that when I'm ready to do a rebuild! 1 Share this post Link to post Share on other sites
