cgenthe
Can I swap differential pinion gear?
cgenthe
I've got two sets of diff/pinion gears. On one set, the diff gear has a tooth missing, but the pinion is in better shape than the one for the other set. Can I swap the pinion for the better one or will the different wear patterns just lead to trouble?
stevasaurus
Is it the same trans for both or a different one...let us know what tractor you are dealing with and where did you get the other trans. BTW...Welcome to Red Square :) The answer is yes if everything is the same. :)
cgenthe
Both sets are from the 5003 tranny. Thanks for the welcome and reply!
sorekiwi
If the gears are the same I would just go ahead and use the best gears available.
The gears in our transmissions are straight cut gears that will mesh OK. In the automotive world with gears cut on an angle and hypoid gears etc you can run into problems with the wear patterns. But on a garden tractor with probably only a couple of hundred miles on the gears, wear patterns arent really an issue. Our biggest problems are usually due to pitting from water in the trans, I dont recall ever seeing a sigbificant wear pattern on a tooth from mileage.
cgenthe
Thanks fellas, not too much knowledge about these things here in dirty jersey! People think I'm nuts when I tell them I'm restoring a tractor- that is untill they see it. Then it all makes sense!
stevasaurus
let us know what you find and take some pictures...we never stop learning here. :)
cgenthe
I am going to swap out the pinion gear, thanks for the advice. Some interesting things I found- on the gearbox sides, there were four small panhead screws per side that I know were not factory. Turns out, someone had drilled holes behind each bearing race in order to remove them easier- they tapped the holes and installed brass screws when they were done. Also, the axles were drilled at both ends- pretty clever, you get a 2nd virgin sealing surface on the axles. I did this on my 2nd set of axles- brand new! New brass sleeves, and seals and I should be good till I'm at least 87!
stevasaurus
can you take any pictures of what you are talking about...I , for one, would like to see what somebody else did to make things work...right or wrong I would like to see. :)
  • Similar Content
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • Robert Concato
      By Robert Concato
      Hi I'm new to site. I am looking for a gas tank for an RJ 35 Tractor any help would be great thanks!
    • wh315-8
      By wh315-8
      Looking for the measurements for items #69 mounting bracket and #79 lifting rod. So that I could fabricate and be able to install on my RJ59. Any pics of the mounting bracket would be a big help.
    • Clay Dodson
      By Clay Dodson
      RAINES AUCTIONS **LIVE AUCTION SEPT 16TH @ 10:00 AM WITH PREVIEW FRIDAY 9:00-5:00 AND ON SATURDAY @ 8:00 AM UNTIL AUCTION TIME**   <CLICK HERE FOR PARTIAL CATALOG>      ^^PRE REGISTER NOW TO AVOID LONG LINES ON THE MORNING OF THE AUCTION.  CALL KATIE AT 540 775 3880, SHE WILL ISSUE YOU A BIDDERS NUMBER.  THEN JUST SHOW YOUR ID AND PICK UP YOUR BID CARD ON FRIDAY AFTERNOON OR SATURDAY MORNING^^           See below for 3 preview videos of the BIGGEST selection ever of Farm Tractors, Garden & Yard Tractors, Riding & Push Mowers, Implements, Bush Hogs, Finish Mowers, Chain Saws, Weed Eaters, Generators, Snow Blowers, Chippers, Tillers and tons MORE all SOLD ABSOLUTE RAIN OR SHINE!!!!    Including 80+ Wheel Horse Tractors, Wheel Horse Raider Models 10, 12, 211-4, 656, 416-8, C-160, Wheel Horse Charger Models 12, GT-14, A100, C160, D160, D200 w/blade, 310 B, 856, 317, 332, 854, 212-6, 211-5, 520-8, 211-3, C-120, Lawn Ranger,  Antique & Rare Tractors including David Bradley Suburbans, Panzer T707 & Chain Driven Bolens, John Deere Models 650, 110, 112 L, 70, 420, 214, 316, 317, 318, 160, 111, 116, 212, 216, 332, Massey Ferguson 135 Diesel, Economy Power Kings & Jim Dandy models 1614, 2414, 2418 & others, Ford, 2 Yanmar 1500 & 2000, Simplicity Models 725 w/blade, 9020, 6216, Baron 7014, 7114, 2210, 3414, 637, 3012, 3410, 728, 3415, 3314, 7116, 7117, 5116 Special, 6211, 9020, Early Speedex Chain Driven Tractor, Scarce Very Clean Pennsylvania Meteor Model 1010, Gravely, Allis Chalmers, Case, Turf Trac, Toro, Cub Cadet, Troy Bilt, Honda, Craftsman and many many others.    ***CLICK HERE FOR PREVIEW VIDEO #1***   ***PREVIEW VIDEO #2***   ****PREVIEW VIDEO #3***     ##LOAD OUT TERMS ARE AS FOLLOWS## THERE WILL BE AN INDEPENDENT PERSON LOADING OUT LARGE MOWERS & TRACTORS FOR $10 PER UNIT IF YOU NEED THAT SERVICE.  DUE TO THE LACK OF ROOM, THERE WILL BE *NO* LOADING USING LARGE EQUIPMENT UNTIL AFTER 2:00 PM. WE WILL SELL THE TRACTORS & EQUIPMENT IN THE FRONT AREA FIRST SO LOAD OUT CAN START ONCE WE ARE DONE WITH THAT AREA, ABOUT 2:00 PM.  YOU WILL ALSO BE ABLE TO LOAD OUT ALL DAY SUNDAY, MONDAY AND TUESDAY THE 19TH UNTIL 5:00 PM.  AT THAT POINT, ANY ITEMS LEFT BEHIND WILL BE SALVAGED UNLESS YOU HAVE PRIOR PERMISSION FROM THE AUCTIONEERS, RAY RAINES OR CLAY DODSON.   ^^SPECIAL RATES AT THE ZION CROSSROADS BEST WESTERN (WHICH IS ONLY 3 MILES FROM THE SALE) IF YOU MENTION RAINES AUCTIONS^^  CALL 540 832 1700 AND REMEMBER TO MENTION RAINES AUCTIONS TO SAVE$$$~     **CLICK HERE FOR HOTEL ACCOMMODATIONS SUGGESTIONS**    Mark your calendar now for this Colossal auction that is not to be missed~    Ray Raines Auctions VA License #3395
