fsjcherokee
Side to rear discharge deck swap HELP!
fsjcherokee
I purchased a rear discharge deck that I was told was off a B-112 I have a 416-8 that the side discharge deck is about shot on. The rear deck is mint and looks to have rarely been used. What do I need to be able to mount the deck from the 112? I tried mounting my deck suport from the 416 onto the rear discharge deck as the deck had the provisions for it bit its too long and narrow? Anyone have the mounting hardware for a 42" rear discharge deck that will fit a 416? I believe the deck model is 05-42XR01 Thanks!post-8467-0-46694300-1347226968_thumb.jppost-8467-0-69509900-1347226979_thumb.jp
TT
:WRS:
Along with the different width of the 48" deck carriage pieces vs. the 42" and 36" deck pieces, the rear mounts for the carriage are different on the RD decks:
You'll also need the correct diameter two-groove pulley for the middle spindle.
fsjcherokee
Ok, on my old deck the spindles are 1/2" and the new one is 5/8" Also my pulleys on the old one are 5" and the new one 3/12". I know I can buy the brackets new on some sites I was looking over today. The pulley on the other hand? Any suggestions? Thank you.
fsjcherokee
Oops correction My "new" deck has a 3/4 shaft so I would need the pulley I believe it has a larger upper "drive" pulley and the lower is smaller 3.35" to match the blade pulleys. I ordered the brackets today still need a pulley?
groundhog47
http://www.partstree.com/parts/?lc=toro_consumer&mn=05-42XR01%2C+42%22+Rear+Discharge+Mower%2C+1981&dn=810171R1-71R10009-0005
This site lists parts fot the 05 42xr01 and Am not real sure if this is what you have, it lists all the "carriage" on a sep page>
And by the way am not hawking or sellin' for anybody, I just had a devil of time gettin' mower parts and like to help where wanted. My knowledge is very limited on all the diff models. If you are just getting in to WH there Tractordata.com fererence page.
fsjcherokee
Thats what my deck looks like now (the setup) but I need to swap over the mounts from my rear deck. I been there but they are $$ was hoping to locate a nice used one. I appreciate the effort.
