cubflyer
Removing paint off cooling fins ( noob question)
cubflyer
Whats the best tool, and best method to removing paint off the cooling fins?
Cole
i like to use a dremel with a small wire wheel or sanding attachment, it fits real good inside the fins and makes them real smooth
cubflyer
Thanks for the suggestions :)
SousaKerry
good stiff wire brush and a lot of elbow grease
or a sand blaster :hide:
Coadster32
I found this will take off a lot of paint when I cleaned the tranny on the 418-a.
http://www.menards.c...y/p-1679710.htm
That could be learned the hard way....as well as brake fluid.
KC9KAS
Oven cleaner works well, but use it in a well ventilated area, and wear gloves....That is some wicked stuff!
Or build an E-tank....http://antique-engines.com/electrol.asp
cubflyer
Thanks for the great information.
