Countdown To Christmas!
Fast N Red
Hydro help
Fast N Red
Hi i have a c-120 hydro that i made into a puller recently at my last pull i had very little wheel speed going forward so i pulled and barely moved the sled so afterwords i went into the parking lot and went forwards(slower than normal) then reverse was stupid fast i never messed with any of the linkage is there any thing i can do? And is there any way to get it to build more pressure?
thank you Fast N Red
Jim_M
Hydros don't make good pullers. I would look for an 8 pinion 8 speed and make the swap.
Fast N Red
i know they dont make the best pullers but mine works ive pulled 5 times this year but i am looking for a 8speed but no one has them
can whlvr
check to see if the linkage where it moves the plastic plate is all working,ive had that happen and it was the ball that slides in the plastic plate,ive also had to replace the plastic cam plate
Fast N Red
i checked it the plastic plate was broke on the left side so it leaned to the reverse side but its getting a 8 speed soon so im not worried
Trouty56
Fast and Red.....what are you going to do with the auto tranny?
Fast N Red
Its for sale. Every thing is good but that plastic place. Linkage and every thing related is n cluded
Fast N Red
Trouty56
Well I'm glad you aren't throwing it away. Sounds like it is a good unit. I'm sure you will find a buyer in your region.
