rhlineman
locking rearend.
rhlineman
Does anyone know how to lock a wheelhorse diff ?
TT
Possibly - what type are you working with?
:WRS:
rhlineman
it is a B80 with 1 1/8 axels hi and low three speed. Thanks
TT
The 8 pinion differential can be "locked" by changing the alternating pinions from this:
To this:
jhunsch
I don’t think its right but I have been known to be wrong before.
I was @ a pull 2 Weeks ago, talking with a guy pulling with a Raider 12.
He said it has a locking axel. I questioned how he locks the axel in, if he had a lever for that purpose.
I never heard of this before and was just curious. He went on to explain that when he pulls forward in
front of the sled he gets real strait to it and needs to be 20 or more feet out in front of the sled then he
backs up slow and strait. He said this strait line backing of 20 feet or more locks the rear.
Yes. ! :omg:
No. ? :confusion-confused:
Or somewhere in between. :eusa-think:
Jeff
TT
If he had a stock :wh: transaxle ~ no. Even if it wasn't stock, I can't see why you'd want some sort of locker that requires backing up 20 feet to engage. :scratchead:
rhlineman
TT.. from the pic you gave it looks like you mated two pinions up two pinions down ? if this is right this is a whole lot better than welding up a locker like i was goin to do. THANKS THANKS THANKS
TT
That is correct - opposing pairs all flipped to one side.
rhlineman
TT.. Thank you very much.
TT
I "painted" a picture:
.....and you are welcome. :handgestures-thumbup:
can whlvr
i did this once by mistake on a 4 pinion rear,it didnt steer very well but climbed hills like a 4 wheeler
