Followers
0
![commando 6](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Rear Hitch is stuck on my Commando
By
commando 6, in Wheel Horse Tractors
Similar Content
By tractorboy79
Hello, I have a gt14 and a old brinly cultivator but I need the correct hitch to put on my tractor (clevis hitch) would clevis hitch fit on the back of a gt14 the same way as a another tractor or will I need to make adjustments? Anything helps? thanks!
By bob54
How do I get this pin out, I've tried heat, rust penetrate, and an air hammer, and just rust penetrate and the air hammer. I can't get it to move, no matter what I do,,and yes I removed the clips from both ends. I knew you were thinking about that
By rwilson
This might be a dumb question but i'm sure some of you have dealt with this. How do you get the pin out of the rear when it is rusted in there? I just bought a clevis hitch today but i cant get the pin out to put it on.
