Fast N Red 5 #1 Posted August 6, 2012 Well i won a Holley black fuel pump and regulator on Ebay it'll be here on Friday or Saturday. Any know what fuel pressure to run and i have some Carb questions. Thank You Fast N Red Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted August 6, 2012 You only need enough pressure to keep the proper level of fuel in the float bowl. Anything beyond that is a waste. Share this post Link to post Share on other sites
Jim_M 179 #3 Posted August 6, 2012 What fuel, what carb, what engine? Share this post Link to post Share on other sites
Fast N Red 5 #4 Posted August 7, 2012 What fuel, what carb, what engine? Kohler k301 ported, shaved head, copper gasket, kohler #26 carb with a 3/4in spacer What fuel, what carb, what engine? Kohler k301 ported, shaved head, copper gasket, kohler #26 carb with a 3/4in spacer and 110 vp racing fuel or 93 w octane boost Share this post Link to post Share on other sites
Deere Hunter 54 #5 Posted August 7, 2012 I usually run between 2-3 lbs when running gas. It all depends what the carb will take, run to much fuel pressure and you will have it running out of the carb. Start at 2 and see how it runs and adjust from there. Share this post Link to post Share on other sites
Jim_M 179 #6 Posted August 7, 2012 I agree, 2 or 2 1/2 psi. What are your other carb questions? Share this post Link to post Share on other sites
Fast N Red 5 #7 Posted August 7, 2012 Where do you drill the hole in the carb when you plug the two vent holes Share this post Link to post Share on other sites
Jim_M 179 #8 Posted August 7, 2012 I assume you're talking about the bowl vent holes being plugged after installing a velocity stack. Just drill a small hole in the carb body in the round area above the float bowl, keep the hole above the top of the float. I like to insert a small tube or hose barb and run a small piece of hose up the side of the carb to keep it from sloshing fuel but it's not really necessary, you have to have a pretty rough ride to slosh any fuel out. Share this post Link to post Share on other sites
Fast N Red 5 #9 Posted August 8, 2012 I assume you're talking about the bowl vent holes being plugged after installing a velocity stack. Just drill a small hole in the carb body in the round area above the float bowl, keep the hole above the top of the float. I like to insert a small tube or hose barb and run a small piece of hose up the side of the carb to keep it from sloshing fuel but it's not really necessary, you have to have a pretty rough ride to slosh any fuel out. I assume you're talking about the bowl vent holes being plugged after installing a velocity stack. Just drill a small hole in the carb body in the round area above the float bowl, keep the hole above the top of the float. I like to insert a small tube or hose barb and run a small piece of hose up the side of the carb to keep it from sloshing fuel but it's not really necessary, you have to have a pretty rough ride to slosh any fuel out. sorry it wont upload my pics Share this post Link to post Share on other sites
