horse junkie
633 wiring
horse junkie
Need a wiring diagram for a 633 any help will be appreciated
Kelly
If I remember right it is one wire to a self grounding toggle switch, that is all the wiring they had, they are a pull start Kohler with nothing on them.
horse junkie
Actually this has 8 Horse Kohler with push button start
Kelly
Factory it was a pull start 6hp Kohler, your going to have to pick a model close and use that, say a 753 or 854 is it a starter gen engine?
CasualObserver
Then this diagram from a 753 might be what you're looking for?
horse junkie
No not starter generator gear starter can I use a 3 prong key switch say from a 1276
Kelly
Are you going to use a start solenoid? if you are you can use a easy to find switch from many tractors that use batt. ign. the 1276 the switch carries the start load, not sure if it will carry the curent the gear drive starter uses? where are you putting the batt.? the gear drive starter in that tractor fits right at the batt. tray.
horse junkie
The way it is set up now there is a toggle switch to energize coil and the push button starter one side from battery other to starter.
Save Old Iron
This will work for you with the points based ignition system ignition switch shown in the diagram. The ignition switch and the starter relay would total about $30 at a farm and garden store. Sounds like you have everything else you need.
