jonsteffen 6 #1 Posted July 22, 2012 yes or no question and reason for answer,what would be better to run tubes in the rear tires or not Share this post Link to post Share on other sites
dennist 139 #2 Posted July 22, 2012 I did read Yes, so you can run lower pressure. Share this post Link to post Share on other sites
baerpath 517 #3 Posted July 22, 2012 Depends if there loaded yes, if just air in them then no. We run 14 inch wide alum rims with Carlsile and Firestone 26x12 Usually around 5 psi(hard tracks) to 8psi (soft tracks) Never rolled a bead on any of the pullers all the way down to 2 psi on slimey tracks. The tube won't push the sides of the tire down as much as the center Duane Share this post Link to post Share on other sites
jonsteffen 6 #4 Posted July 24, 2012 Depends if there loaded yes, if just air in them then no. We run 14 inch wide alum rims with Carlsile and Firestone 26x12 Usually around 5 psi(hard tracks) to 8psi (soft tracks) Never rolled a bead on any of the pullers all the way down to 2 psi on slimey tracks. The tube won't push the sides of the tire down as much as the center Duane thanks you two by the way baerpath i want to pick your brain for some tips and tricks in the pulling world for wheel horse tractors Share this post Link to post Share on other sites
stephan07 10 #5 Posted July 24, 2012 13 wide alum wheels no tubes here best combo i have used. they may be for sale if your interested. Share this post Link to post Share on other sites
jonsteffen 6 #6 Posted August 5, 2012 i am going to run 23x10.5x12's with steel rims with 23x11x12 rims so would i use tubes or not Share this post Link to post Share on other sites
