Terry701
WH Shows - Mid-West
Terry701
Hello - I was wondering if there are ever any Wheel Horse Shows in the the Easter Missouri / South West IL area. I have a 1961 701 I would like to show. Or if anyone knows of a list of shows posted anywhere.
Thanks,
Terry 701
stevasaurus
Terry, there is a show in Jacksonville, Ill. September 28, 29, 30. Check the general shows and events section. :)
ol550
Good lookin 701! Your boy looks happy to be part of the show. Just keep your eye on
thresher and antique tractor shows. If you are able the North Central Indiana Meet and
Greet is a one day event and well worth the trip. Mike
Terry701
Thanks for the tip - The one in Jacksonville would be ideal...except I am getting married that weekend I will try show and even section - thanks to all for the help!
Rooster
Sounds like a Honeymoon at the Show to me??
I'll bring the Champagne ;)
Lane Ranger
Terry: We need you there! I am taking some tractors and have asked Martin from Geneseo, Ill, Denny Clark from Pawness , Illinois and others to show up . It is a great place for a show. My daughter lives there and we will be about ten blocks from the 150 acre site.
Last year only one wheel horse was present!
Mike (the lawn tractor guy in charge of that portionof the show is restoring two wheel hroses this year also!
Date: Sep 28 - 30, 00 PM 217-245-5905 Location: Illinois Prairie Land Heritage Museum Institute - Steam Show & Fall Festival Days. This year our feature tractor & equipment is Ford and Fordson. Threshing, baling,sawmill, sorghum mill, steam engines, stationary engines, antique tractor pull, garden tractor pull,camp grounds, crafts & flea market. Tractor parade Saturday and Sunday. , So. Jacksonville/Jacksonville, Corner of Lincoln & Michigan Ave., So. Jacksonville, Illinois, Show Chairman, Hank Pool, 217-473-7431 or after 6.
http://prairielandheritage.com/index.html
Lets raise the Wheel Horse flag this September and get some more Wheel Horse tractors at the Show!
  • Similar Content
    • buzzard440
      By buzzard440
      1961 701 for sale complete and original w/ mower deck. Runs but needs TLC.
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
