Countdown To Christmas!
coldone
D series sundstrand pump model number?
coldone
Has anybody got the number off the sundstrand tag on the pump?
I have a great hydraulic remanufacturer up the road, they said they would be glad to see if they could get parts for the hydros. I have the motor tag number and will see what they can do with that.
wheeledhorseman
Any idea where it's located on the pump?
Andy
coldone
My motor had an aluminum tag that fit under one of the housing bolts. i havent looked at my pump cause I havent had to strip it down that far yet.
Tap53
Here's the numbers I had written down when I ordered part for D-200.
All the numbers they need should be here.
90-1137 IH
310235602
04-SK 16847
Tim
JamesBe1
I'll check mine in the morning. Hopefully it is the same as the rest. I may have one or two old ones collecting dust (actually rust) somewhere. I'll add that info too. Can't hurt to see if we have mostly the same model(s).
I wonder if we can get a group discount on rebuilds if we all get together. I might consider two of mine if the price isn't off the charts.
pfrederi
90-1137
3102464-03
03-pr 28480
coldone
Thanks. I wil add my motor numbers
90-1137
3102464-03
03-PD Z322
last 4 could be 2322
JamesBe1
I looked at my two D's and my spare (junk) motor. I can't find the tag on any of them. I could have sworn that I had in the past seen at least one tag. Maybe tonite I'll pull the wheel off and take a closer look.
Kevin Bowley
I believe it is a Sunstrand 930 transmission, mine is the same as the others, 90-1137 IH
Hodge71
90-1137
JackC
From my 1977 D-160.
The tag on the trans-axle indicated the following:
Sundstrand 90-1137 LH
3102464-04
04-TB 1458
Does anyone know how to decode the numbers?
wheeledhorseman
Here’s my best shot on the numbers based on a bit of research
90-1137 is a sundstrand reference to specific transmission, in this case one they built built for Wheel Horse.
Taking 1974/75 as an example auto trannies were as follows:
Sundstrand 90-1136: B-100, C120,
Sundstrand 90-1137: D-160, D-180, D-200
Sundstrand 90-1140: C-160
I haven’t checked mine yet but I’d expect 90-1137 to appear on both the pump and motor units as they are separated in a D transmission. I'll try and look tomorrow.
3102356 and 3102464 are the Sundstrand reference / part number for the specific pump unit (we know there are two different casings with different motion controls fixed externally to them).
Not sure about the -02 and -03 but these could be revisions perhaps?
The last sequence of nn xx nnnnn – I’ve really no idea, production numbers / date code / serial perhaps.
I’m almost certain that the 90-1137 does not indicate Sundstrand Series 90 technology. If there is a similarity between these transmissions and a specific Sundstrand ‘Series’ then the closest I’ve found is to ‘Series 15’ and I suspect that the transmission built for WH was one of the variants based on date, similarities between manuals, and, it has to be said, the Sundstrand part numbers for components specific to the 15 series which appear to be 310 followed by a further four digits.
These can be rebuilt because generic parts like replacement plates, piston and cylinder block units appear to be available but I suspect these are aftermarket products rather than OEM. I also suspect we’re talking expensive! I also picked up from a conversation with a specialist in the US that in the case of springs, ball bearings, O-rings and the like, they simply use standard parts.
If any of you find a helpful chatty local company then I’d dearly love to know if the WH tranny is a variant of the Series 15 or if not then which series it belongs too. Sorry about another ramble but I know some of you appreciate.
Must try and remember to look for the numbers on my D tomorrow.
Andy
coldone
I am suspecting that the 90-11xx number is Sundstrands unique ID code for a pump and motor that the WH engineers spec'ed out. In the states this is refered to as an propriatary part. A company (WH) contracts another manufacturer (Sundstrand) to make a part to a specific set of parameters set by the company (WH). It could be something as simple as bolt spacing, mounting option, tolerances etc.. In my expeirence with these types of propriatary assemblies the manufacturer (sundstrand) will use mostly off the shelf parts for the assembly to meet the customers demand. Most companies (WH) do not want the expense assaciated with a fully custom assembly, think retooling an entire assembly line. The advantage to us (the end user) is that alot of parts will interchange with other standard assemblies and that rebuilding tolerances and techniques are not unique to the propiatary assembly.
My hopes are that there will be parts that are interchangeable with current production units, valve plates, gaskets, and cylinder assemblies. My guess is that the motor shaft will be unique and that the relief valve settings will be unique.
If it does turn out to be 100% propriatary the we can contact toro to see if we can get a letter of release for the info from sundstrand.
wheeledhorseman
Another jigsaw puzzle piece.....( and another reason for suspecting that these were based on 15 series components)
Model / product numbers for Sundstrand 15 series hydrostatic pumps and motors designed to operate as separate entities began with the digits '15' but the model / product numbers for 15 series transmissions, where the two are designed to be physically attached to each other, began with the digits '90'.
This was true for both inline and 'U' configurations (where the pump sits on top of the motor).
Although the WH 'D' series tractors have a separated pump and motor, the pump and motor are actually designed to go together as a single unit hence the '90' classification. The manifold that connects them was a specifically WH thing.
Andy
coldone
Finally have gotten some info. Very long story shorttened,
LJ Fluid power
10118 S M 43 HWY
DELTON, MI 49046-9602
(269) 623-5136
Has the parts we need, valve plates, gaskets, cylinder assy etc. Most of the pump parts are interchangable with the 15 series sundstrand pumps, valve plates and such. The unique stuff is in the motor, thats pretty much non interchangable with anything. He said to just give him the wheelhorse part numbers from the manual.
His prices for parts are comparable to what I am seeing on ebay for the sundstrand 15 series parts.
The man to ask for is LJ himself.
For our brothers across the pond, I am sure we can get you the parts you need.
wheeledhorseman
:banana-wrench: Great news and a valuable addition to the hydrostatic knowledgebase! :thumbs:
Always suspected that the WH/Sundstrands were based on 15 series so it's also great to have that confirmed also.
It may well come to needing to take you up on that offer sometime in the future but I'll see what I can find out re availability of 15 series parts over here when I get a chance.
Andy
JamesBe1
That's great to know. Now we aren't stuck in limbo whenever we have pump problems.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
