Countdown To Christmas!
radarme
C-121 taking shape.... need a little decal help
radarme
I have a few remaining decals in my set for the C-121 auto and I have no idea where they should be located ... Any help?
Thanks,
David
post-5908-0-38064300-1339982669_thumb.jp
post-5908-0-89609900-1339982694_thumb.jp
post-5908-0-87043900-1339982715_thumb.jp
Kelly
The first decal I'm pretty sure is for hyd lift, and you don't have that so not needed, the second I'm not sure, but I think it goes on the starter, I believe the starter would have 2 decals one stating do not strike ....... and I don't remember what else, the last I think goes on the fender if you flip up the seat and it goes next to the hole the trans fill tube is located through, I'll go look at my C-121 and 141 autos in a min. and check back.
Kelly
Ok here are pics of my C-121 the one decal you will not need as I stated it is for hyd lift, the starter decal is different than mine but probably goes there, I looked at 4 diff. starters all were the same as in the pic, and the last decal does go under the seat on the fender.
radarme
thanks Kelly!!
AMC RULES
WOW! That tractor is gorgeous.
Jake Kuhn
That tractor is beautiful! :bow-blue: Jake
jay in nc
very nice tractor, comming out party in pa. thiss weekend? Jay
radarme
I may need to plan for the PA show year.... that's a haul for me...
312Hydro
You did a beautiful job on your tractor . :thumbs:
Anglo Traction
As has been said David, you've done a terrific job on it. Your second Decal goes on the Shroud (the Starter Motor Blister) as in the pic on the left here. Hope you haven't already applied it.
post-3520-0-45146300-1340239030_thumb.jp
Regards.
meadowfield
next to the other decal - rarely seen, but necessary...
:laughing-rofl:
radarme
ok, next question..... now that I have put the wrong decal on the engine shroud, is there a good way to remove and still reuse?
