jimbo7921 8 #1 Posted June 16, 2012 just wondering if anyone can help me narrow down where to look for a wiring issue. when i turn the head lights on i keep blowing the 30amp fuse for the charging system, as well all the gauges stop working i figure its a bad ground but am really not sure where to start looking for it or even what colour wires to follow. any help would be greatly appreciated Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted June 16, 2012 First thing to look at is the 9 pin connector that plugs the engine into the chassis (in front of the battery). 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,071 #3 Posted June 16, 2012 If you have a pile of good fuses handy try replacing the fuse and turning on the lights with the hood open. Maybe with it closed your pinching a wire. Mike........... Share this post Link to post Share on other sites
bwh3200 1 #4 Posted June 18, 2012 Jimbo, I just installed a new 9 pin connector and fuse block on my 520H and now everything works like new. I purchased the original type 9 pin connector and did not use it because of the quality. I used an automotive type connector.I did use the original type fuse block. I also purchased and installed a new ignition switch. I know for sure that the rectifier pin was bad in the 9 pin but not sure what else was bad i just know that now everything works great. By the way these parts are all inexpensive. Do you know how to use a Volt meter? I will be happy to help you out. Share this post Link to post Share on other sites
jimbo7921 8 #6 Posted June 19, 2012 bwh3200 any help would be great i can get a hold of a volt meter but honestly have no idea how to use one. Pulled the 9 pin connector apart this weekend, thought it looked ok, cleaned a few connections up and made a new battery lead and put it all back together. Know the charging system isn't charging the battery at all i have had to replace the regulator before hopefully not again Share this post Link to post Share on other sites
jimbo7921 8 #7 Posted June 20, 2012 does anyone have any idea why turning on my lights would blow the regulator? Share this post Link to post Share on other sites
JackC 617 #8 Posted June 20, 2012 The lights should be on a 10 amp fuse. Are the fuses in the correct sockets? Possibly one or more wires may have lost their insulation due to some rubbing or vibration and are making an incorrect circuit. I would first carefully inspect and check all the wires in the lighting circuit. A wiring diagram would be essential and a meter very helpful. Share this post Link to post Share on other sites
bwh3200 1 #9 Posted June 22, 2012 Unplug the headlight connector and try turning them on. If the fuse blows then its somewhere between the lamp switch and the plug. If not then its in the lights. My problem with the lights and everything else electrical was in the 9 pin connector and or the fuse block Share this post Link to post Share on other sites
jimbo7921 8 #10 Posted June 22, 2012 bwh3200 what did u use to replace the 9 pin connector? thx jim Share this post Link to post Share on other sites
bwh3200 1 #11 Posted June 23, 2012 Jim I used these connectors. The connectors are inexpensive but the crimpers are expensive. I managed to use a crimper that i had in my tool box and made them work, it was a pain. I think the proper crimper is a"F type". I used two 6 pin connectors because there were no 9 pins that i could find through Weatherpack. Good luck! http://www.amazon.com/Performance-Products-Individual-Female-Connector/dp/B0081ZY4ZS/ref=sr_1_15?ie=UTF8&qid=1340450255&sr=8-15&keywords=weatherpack+connector Share this post Link to post Share on other sites
Todd 2 #12 Posted November 11, 2012 The lights should be on a 10 amp fuse. Are the fuses in the correct sockets? Possibly one or more wires may have lost their insulation due to some rubbing or vibration and are making an incorrect circuit. I would first carefully inspect and check all the wires in the lighting circuit. A wiring diagram would be essential and a meter very helpful. jack were is this 10 amp fuse i cant find one anywere on my 520 ,,i have 30,25 and 15 in the fuse block but no 10,is there a inline 10 amp somewere ?? Share this post Link to post Share on other sites
Save Old Iron 1,565 #13 Posted November 22, 2012 Jimbo, do you have this under control or do you need additional help? Share this post Link to post Share on other sites
Amanda 81 #14 Posted November 22, 2012 You have a short to ground, somewhere the power feed is grounded. Share this post Link to post Share on other sites
