jaydeer
520 8 speed replacement
jaydeer
COuld anyone tell me what rear ends would fit in a 520 8 speed? Someone stopped for a 520 rearend, which I had in a hydro, but his was a 520-8. I was not sure if the axle was longer thatn a typical 8 speed. Any help would be appreciated.
can whlvr
so i looked up a 41-20o801 which is the 520 model and compared some parts like axle,some gears to my 1989 414-8,it has the same rear end,which gives lots of options,all 400 series 8 speeds,maybe some of the later 300 series with the 1 1/8 axle,these will be a direct bolt in,but maybe some older c series would work too,but i have not done it so the shifters might be a little diferent but may work also,hopefully someone has put a c in one,but there werent too mant 520-8 made,and they are relatively new so i wouldnt think too many of them would need new rears,but the 400 series will work and theres lots of them around
