bo dawg
Proper wiring of amp meter
bo dawg
I've been learning a lot lately on wiring up these tractors (never been my best subject). I went by a C series 1978-79 wiring diagram for my 82 SK486. It was a bit hacked up but for the most part was wired pretty much to the diagram I found.
My question is what is the best way to run the wire for the amp meter?
I have the battery cable running to the solenoid then from that same solenoid post a wire going to the amp gauge, then from there to the ign switch post ( B ) battery.
The B+ wire runs from the Rectifier to the ® post of ign switch.
I had replaced a car amp gauge that was installed by PO with a normal WH supplied gauge. The other didn't read anything.
But now the amp gauge needle reads but never runs in the positive side of gauge. If anything leans toward the negative side. Then when I turn lights on it really go's negative. I haven't checked with volt meter yet if it is charging correctly. Want to make sure I'm using correct wiring first.
I also found a C-series 1982-83 diagram that shows feed from the amp gauge to the B+ post of rectifier then from there to the ign switch post ( B ).
So which is the correct way to go?
Save Old Iron
Appears you have everything hooked up correctly as in the diagram below ( if the ammeter + wire is hooked to the battery post or to the solenoid post with the battery wire, it is still electrically the same connection).
(click on the image to enlarge)
Sounds like you have a charging issue. Check the voltage at the B+ terminal of the regulator with the tractor running at least 3/4 throttle. You should be able to measure in the range of 13.5 to 14.5 volts at the terminal. The ammeter will only swing positive when the voltage at the B+ terminal is higher than the battery voltage. The ammeter swinging negative when the headlights are turned on confirms you have the polarity of the ammeter wiring correct.
Larry Chamberlain
What ot you have a toggle and push button how do you hook it up then
lynnmor
Since the electrical system has been knackered, why not eliminate the useless ammeter and install a voltmeter between the toggle switch and ground?
gwest_ca
12 hours ago, Larry Chamberlain said:
What it you have a toggle and push button how do you hook it up then
Battery to toggle switch to ignition coil (+)
Battery to push button to small terminal on solenoid
To remove the ammeter join the 2 wires and insulate the connection. If you don't have a fuse wire a heavy duty (30 amp) fuse holder in between the 2 wires but use a 15 or 20 amp fuse in it.
To add a voltmeter power it with the wire going from the toggle switch to the coil (+) and voltmeter (-) is grounded.
Then power the toggle switch and push button from the fuse protected side of the fuse holder as a battery power source.
Does that answer your question?
953 nut
Rather than hitch hiking on a thirteen year old thread you would be better off starting your own post.
Racinbob
:rolleyes: I liked the simplicity of the diagram and until you mentioned it I didn't see that it was an old SOI post. He hasn't been around in years. :)
kpinnc
While I agree completely, my hat is off to anyone who uses the search feature. I'm guilty myself for not using it each time of course.
@Larry Chamberlain- you can always link the old thread in whatever new one you create if you want to keep the reference tied to your post.
Edited by kpinnc
Larry Chamberlain
Ok gotchya i figured this would have been the easiest way but will do different in the future
953 nut
The reason a new post is desirable is that it will show up on the HOME PAGE topics listing and will result in more eyes seeing it. Tagging onto an old post is easy to miss.
