boovuc
Snowblower "Wheels"
boovuc
Hi Everyone,
This winter, I want to try something on my snowblower. I use a singlestage snowblower on my C-175 for blowing snow when I'm not using the plow.
I know "some" snowblowers use casters or wheels rather than what mine has which are "skids" to make ground contact.
I want to convert my blower to casters or wheels. Is there a kit? Does anyone have an old blower they would want to part out that uses anything other than the skids?
I have a paved driveway and so do my neighbors that I use it on. Any help would be welcomed. My blower is a Model 79360. S/N: 4900900.
Thanks in Advance.
AMC RULES
Why do you want wheels vs. skids?
squonk
I made some wheels for my Single stage hi-chute blower. I got some 3/16 plate and made mounting holes in them just like the original skids for adjustability. I welded on some solid round stock for axles and drilled them for cotterpins.Then I got some decent 6" wheels from TSC just like :wh: deck wheels. I haven't tried them out yet. I got the blower this spring and had ZERO snow. I do have a gravel driveway. Blower is all sealed up and put away so no pics. BONUS!! Wheels do make the blower easier to move around when not attached to the tractor! :thumbs:
smoreau
The older blowers has cast iron wheels around 2 1/2" in dia. They didn't work well IMHO and the skids that you all ready have is what most go to as they work much better. You want to put on 6" wheels, the biggest issue I found was that the wheels made it harder to turn with the blower down, and the wheels would drop down into holes and make the blower dig into the gravel, yard, or drive. It sounds like your using yours on concrete drive and now that I think of it, you should be fine with what your doing. Just make sure the swivel so you can turn as that was my issue.
Martin
if you are worried about the steel skids tearing up the surface of your driveway you could install hard plastic skids. i dont know what shape the skids are on yours but on my ariens snowblower first thing i did was replace the steel skids with plastic.....
can whlvr
doesnt your blower have the adjustment handle,thats where the wheels slide on and are held by a cotter pin,sorry no pic right now
boovuc
I have HDPE under my skids now but with the weight of the blower, I wonder how long they will last. I thought that a wheeled blower would work better with less wear on the driveway and would be easier to move around when off the tractor.
AMC RULES
I've never know the skids to produce any noticeable wear on my asphalt drive, and it's seen some better days.
I did make up a wood frame with casters, that I set the blower on before removing it from the tractor, it sure does make moving it around in storage that much easier.
SNYFIX
Why not both !! A skid for blowing the snow and then wheels for moving it around. Okay, geniuses, time to get to work in your machine shop !!!
  • Similar Content
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
