1maidenfan
D series sundstrand hydro pump NOS
1maidenfan
Found this surfing around on :techie-ebay: ...
" 106459 Toro Wheel Horse Hydrostatic Sundstrand 90-1173 Transmission Assembly Piston to Piston Complete. Brand new in Box in Perfect Condition. "
Item number: 170757789526
At $899 it's not cheap but the add says it is NEW. :dunno:
Trouty56
Interesting....... expensive too!!!
AMC RULES
WOW!...and going south on 69, that's driving distance for you too. :popcorn:
1maidenfan
I dont really need one, all my D tractors drive great. Just wanted to let every one here know about it since there are people that might need this and from what a couple of you have found out, it is very costly to have one repaired
JamesBe1
Yeah, it sounds cheaper than having one repaired. But I wonder what kinda of condition it is in after sitting around for 20 or 30 years in a box. Still, it is intriguing.
JamesBe1
I did a search on ebay for Sunstrand. I came across lots of pistons and cylinder blocks for several different series pumps.
Can any tell he what series pump is used on the D-Series? Would the series possible be "90" as per the part number prefix?
wheeledhorseman
I've been thinking about that James and it's an assumption I have tended to make but I don't think it can be the case as Series 90 stuff from Sauer-Danfoss (formerly Sundstrand) appears to be pretty much current and all the spares would still be available for our pumps and motors if that were the case. It's possible / probable then that the 90- prefix was a WH generated code. I'm sure Paul will know the answer.
What I did read somewhere was that WH beat IH and JD to introducing garden tractors with hydros by a few months but whereas IH and JD opted for Sunstrand hydrostatic systems WH used the hydrogear system, subsequently switching to the more reliable hydrostatic. The system IH and JD were using was the 15 Series. This led me to a Series 15 manual which, although the hardware looked different to our WHs, the manual has many of the same diagrams used in the WH / Sundstrand manuals. The manual also contains a way better description / explanation of how our systems work than I've come across in the WH manuals.
Hydro experts please feel free to shoot me out of the water on this one by my guess is that our hydrostatic systems are 15 Series derivatives or there abouts and certainly 'obsolete' as far as the manufacturer is concerned.
Andy
can whlvr
some parts were available when i tore my sundstrand open,i needed the slipper ring for one,it was avaiable,but there were a few parts the shop had made at a machine shop,i paid cash so didnt get a bill to know what parts he had made,but it surprised me that some parts were avaiable
1maidenfan
Your geography is right on :handgestures-thumbup:
1maidenfan
Andy
Thanks for the instructions on becoming a "Dysfunctional 'D' family member" Hope no one disapproves. :happy-jumpeveryone:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
