coldone
D200 Hydro testing
coldone
I purchased the parts to make a gauge from Surplus center. Total cost was about $27 including shipping. It arrived about two weeks ago and I finally got some time to use it this weekend. I installed it first in the top hole (11/16 cap screw) thats the wrong hole for the 1/4 MPT. I had to take out the temp gauge (9/16 wrench) to acess the correct size port. WIth the rear wheels jacked off the ground my intitial readins were:
At idle Nuetral=50PSI
Forward/rev= 25PSI
At full throttle Nuetral =75-100PSI
For/rev= 60-75psi
Implement travel= 200psi
Implement full stroke= 400-450psi
Checked the Charge pressure relief valve and found no problems with it. Retested and had same pressures as before.
Checked the Implement relief valve and found no problems. Retested and all pressures went to 0psi. Found I had dropped the two shims that were in there. Reinstalled the two shims and had same pressures as before. Each shim measured 0.25inch diameter and 0.075 thickness. I made a third shim from 1/4X20 bolt, 0.025 diameter and 0.066 thickness. Installed third shim and tested (here is where it get strange)
At full throttle implement full stroke raised to 600-650psi
Neutral= 125psi steady
When I cycled the direction lever forward initial pressure at full forward was 100psi but started dropping and settled at 40-50 psi. When I rechecked the impl full stroke, it dropped back to the 400-450psi range. I never saw the 600psi again in any of the folowing tests.
After that i had to start checking the check valves. I had to make a driver to fit the screws. I tried a few different things but had no luck. I ended up taking a 3/4inch paddle drill bit and grinding the end flat. 3/4 was too wide to fit in the hole so i cut it down to fit. (A 5/8 bit should work but I have several 3/4 in so 1 was sacrificed). Using an adjustable wrench as the leverage arm for the bit I placed it into the screw. I gave it a few good whapps with the hammer to make sure it was seated good. It did seat good because the adjustable was slipping on the hex shank of the bit. Back to the grinder and I made two big flats on the hex shank. Well after that it worked. Be warned that when the screws finally let go, you will think you broke something.
both check valves looked ok. Last pressure test reading were the same as the first.
I decided to take it for a test spin with the gauge still installed. At first things felt a little stronger. I went over to a fallen tree Thats bigger than the front tires. I put the front tire up to the tree that was on the ground. I gave the control lever a little nudge forward and my pressure dropped from 75psi to 20psi. At full throttle and full forward stick my pressure dropped to 0psi. The entire test run, from barn door to final push, was less than 3 minutes.
I guess my next step is to start inspecting the motor and accel valves.
Here are some pics of my redneck/bodged tool
ETA: Not sure my I cant put them all in one post.
coldone
JackC
Clever tool you made.
It took me awhile to find one that fit the hole but I did find a 3/8 drag link bit.
I have not used it yet and it this is not it but this is what it looks like:
1maidenfan
Ok I am at a loss here :confusion-confused: What are you using the homemade tool for :confusion-shrug: Looks like an altered spade bit.
wheeledhorseman
A great bit of 'red neck tech' there coldone - for me it's answered where to get the hardened steel to make a tool in the style of the drag link bit used by Jack. Unfortunately I damaged the slot in an attempt to use an impact wrench so my thoughts were running along these lines. Paul sent me a spare end cap screw so now I should be able to make a tool and pray!
Re the hydro -
Unfortunately the various Sundstrand manuals contain different content but I have one that has a detailed description of how the relief circuits work which together with the diags showing states in neutral, forward and reverse found in all versions of the manual perhaps give a reasonable understanding.
As far as I can make out..... the charge relief valve remains shut until the charge pressure reaches somewhere in the 70 -150 psi range. The pressure generated by the main pump is fed to the hydro drive pump only until the valve starts relieving at which point it alows oil to bypass through the implement control circuit. It passes through the implement control valve assembly and back into the system to return to the reservoir. It's a critical feature of the desgn that the implement control valves be the type that alows an open flow through them in the 'neutral' position. It this pathway is partially blocked for any reason the charge pressure will be higher than it should be for normal operation. A dysfunctional D high pressure problem could relate to this. I have come across a hydraulic hose in the past where the rubber had swolen internally reducing the bore down to a very fine hole which fluid would still pass through at high pressure.
When an implelent valve lever is operated this bypass flow is directed to a ram moving it until it reaches the end and there's nowhere for the oil to go. At this point pressure in the whole system rises rapidly to the 500 -700 psi range at which point the implement relief valve opens alowing oil to bypass the implement circuit and return to the reservoir.
The motion drive circuit between hydro pump and hydro motor is effectively a sealed circuit but both do leak some high pressure oil by design hence the need for the charge pump that replaces these losses. If for some reason the loss has gone off the scale that the charge pump can cope with then along with the charge relief valve not seating correctly then this could also account for low pressure dysfunctionality.
That's about the best explanation I can give. I'm sure Paul will chip in if I've got anything wrong here. If anybody with a dysfuctional D wants a copy of the Manual that has a pretty detailed explanation in it send me a pm with your email and I'll forward the pdf file.
Andy
coldone
Yeah a drag link was what I needed but I was running out of time to work on it so i had to improvise a field expedient item. :D
Thats execatly what it is. It is for taking out the screw caps that hold in the check valves that are located in the pump block.
Andy, Check your PMs.
Britt
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • Nathan W
      By Nathan W
      Does this look factory for 1976
