njdpo 8 #1 Posted May 21, 2012 Hi all, Starting a new thread ( from the subject of working on a mechanical fuel pump issue) . I have replaced a mechanical fuel pump on a K321S engine. The old pump is now leaking some oil from it - it needs to go. Where can I find a Kohler K321 fuel pump - block off plate ? Thanks - Dave Share this post Link to post Share on other sites
WH854 44 #2 Posted May 21, 2012 Hi all, Starting a new thread ( from the subject of working on a mechanical fuel pump issue) . I have replaced a mechanical fuel pump on a K321S engine. The old pump is now leaking some oil from it - it needs to go. Where can I find a Kohler K321 fuel pump - block off plate ? Thanks - Dave Try this site. http://www.kirkengines.com/ Chas Share this post Link to post Share on other sites
MikesRJ 552 #3 Posted May 22, 2012 It sounds like you've already replaced the mechanical pump with a pulse pump, but if you have the older style metal or plastic fuel pump, there are rebuild kits available for them. Try here http://www.maritimedragracing.com/then_and_now_automotive.htm Share this post Link to post Share on other sites
njdpo 8 #4 Posted May 22, 2012 Turns out if I google on kohler fuel pump cover - you find there is a part number... 240282-S - PLATE, FUEL PUMP COVER The rest was easy... Share this post Link to post Share on other sites
wheelhorse656 20 #5 Posted May 22, 2012 I have a couple of them for 2.50 plus 75 cents shipping. I use them on my tecumsehs and kohlers. Both take the same pump only difference is pump arm. Share this post Link to post Share on other sites
