bean 85 #1 Posted May 11, 2012 I was riding on the 73 8hp today and noticed the key had 2 positions. "run" and also "run plus accessory". how is the second position different from the first? :huh: Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted May 11, 2012 Hey bean, I can't say for sure about your 73-8, but on my GT-14, it has that switch set up. The ACC position is for the electric clutch and any other accesories that might be on that circuit. As an aside, I love your fovorite model too! 1 Share this post Link to post Share on other sites
rmaynard 17,553 #3 Posted May 11, 2012 From the owners manual: "The ignition switch has four positions from left to right (1) off, (2) run and accessories, (3) run, (4) start. To start the engine, turn the key all the way to the right. Release the key when the engine starts and it will automatically return to "run" position. The key must be turned back manually to "run and accessories" position before the optional electro-magnetic clutch or electrical accessories will function. When the switch is turned off, the engine stops end all electrical accessories are turned off as well." Hope this explains it. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #4 Posted May 11, 2012 My Case 210 has the same thing. a (4 position switch) which is how you turn the lights on for it. Share this post Link to post Share on other sites
bean 85 #5 Posted May 11, 2012 thanks, i actually did break down and read the owners manual a few minutes ago. went against every manly instinct. :cry: 5 Share this post Link to post Share on other sites
AMC RULES 37,259 #6 Posted May 11, 2012 Yep, like assembly instructions too...only as a last resort. 1 Share this post Link to post Share on other sites
wh-jason 33 #7 Posted May 11, 2012 instructions are just another mans opinion. :ychain: 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #8 Posted May 11, 2012 instructions are just another mans opinion. Just because they have an opinion that they can't keep to themselves...doesn't make them right. :ROTF: 1 Share this post Link to post Share on other sites
wh-jason 33 #9 Posted May 11, 2012 Exactly!!! (null) Share this post Link to post Share on other sites
