Countdown To Christmas!
buckrancher
Need Sickle Bar Mount
buckrancher
Hi guys I need some help here I need pictures and dimentsons for the travel bracket and mount
for a sickle bar mower to fit a 854
or If someone has one to sell
or loan me one to copy I will pay for all shipping
Thanks
Brian
jimt1971
Brian,
Buzz should be able to help you he has one of those sickle bars mounted.
Jim
Gene_S
Brian are you talking about the bracket the travel hook mounts to???
buckrancher
yes Gene I need the mount that bolts to the hoodstand and the travel hook
Brian
Gene_S
Brian PM me your address and I'd be glad to mail you my hook and mount to copy.
wp205a
I too am having problems with an 864/sms-42-a. Missing the travvel mount mentioned above and rod-lift part # 3495. My bigger problem is finding where the rod-lift fits into assembly frame (weld) # 1954. Thanks for any advice you may have, I just can't figure it out.
buckrancher
there should be a 3/8" hole on the back side of the welded frame where the pulleys mount for the belt to the gear box for the lift hook remove the 4 small bolts and front cover to put a cotter pin in the lift rod
I have a extra travel hook and mount for $40.00 plus shipping if you need one
Brian
wp205a
Serial # A-19750 on the mower, if that helps. There's NOT a hole in the assembly frame that I can find. Thanks
wp205a
Going to look for that 3/8" hole right now. Thanks
wp205a
Unless it's one that's used for something else, I don't believe it's there. If I can get the thing out of the dirt I'll be interested in that travel mount. I really appreciate your time. And I have no idea where that line through my previous post came from.
buckrancher
I just went out and looked at mine I have two with the 3/8" hole and one without and your right the one without the hole
I do not know how the lift rod attaches
Brian
wp205a
That makes me feel better, I think. Can you give me a rough guess as to where to drill a hole to get it in the approximate area? I want to put this thing to work, but it's a go no further as it stands now. Need one tooth (section) that I was planning on having made by a fabricator friend of mine, 2 new belts, Wobble box seems tight, the assy frame needs a little tweaking as the pull up to travel position bar is sloppy. The tractor itself is as good as I could ask, after a week of work. I'm done worrying about it for today. Have a great week.
wp205a
I just realized that I called my tractor an 864, when we all know it's an 854, made in 1964. I apologize for that egregious error. Now I'm going to bed.
wp205a
I'm now convinced mine is a sms-42, without the lift rod. My plan is to alter it into a 42-A. Brian, I discovered your 854/sickle project earlier, fantastic job, and the pictures really help. I have the mower disassembled to a point that I can work with it. Al.
buckrancher
I will see if I can get a pic of the hole and location for you
Brian
wp205a
Thank you so much. I also saw your stainless steel tractor pictures. Outstanding job! Have a great afternoon.
Al
buckrancher
Hole size is 3/8"
Brian
wp205a
Thank you sir.
  • Similar Content
    • 2003Chevy
      By 2003Chevy
      Hello All!
      Added THREE tractors all at once yesterday(09/16/2025).  Two model 854, and one model 855.  The two 854 look pretty nice, but are not running right this minute  --does not look like much more than a little tinkering/refreshing after sitting for a long time.  The 855 was labelled a "parts" tractor, but except for it being Really well-used looking, it seems to be all there so I am not going to consider it out of play yet.  The two 854's have rear discharge mower  decks...one is a square style deck, the other the rounded style deck.
      I think it is really nice that all three are basically the same machine, separated by one year, yet completely different styles--the end of one era and the beginning of another I guess.
      There is an ID tag on the 855 (serial number 135166) but on the two 854 tractors, there is No tag under the steering like late models.  Are the tags in a different place on older machines?  Looking them over, I do not notice anything obvious.  The 854 with the lower Kohler engine serial number has the round style mover deck, while the one with the slightly higher engine serial number has the square style deck.
      All for now!  Be well and stay safe.
      [rayg]
    • dlashb40
      By dlashb40
      As a retired 61-year-old who inherited 4 of my Grandfather's Wheel Horse tractors, I found a valuable resource in this forum. Here, I connected with Bob Parks (Racinbob), who at the time lived nearby and kindly agreed to help me identify all of them. I ended up keeping the 1964 Model 854 and sold the others. The 854 is a solid, primarily original tractor, and I've been using it since I was 6-years-old. I also had the RM-364 mower deck attachment, which had not been on the tractor for many years. Once again, this forum proved its worth as I could identify and obtain some attachment parts that I was missing. Last week, after some adjustments, I put the mower deck to use and mowed nearly an acre of grass without any issues. The sense of accomplishment in identifying and restoring the equipment was truly inspiring, and I felt like I was a kid again.
      As someone who doesn't consider themselves 'mechanically inclined,' I've grown and learned much through this project. I want to express my heartfelt thanks to all of those who guided me and showed me that with the right support, even the most daunting tasks can be tackled.
    • Bodean
      By Bodean
      In search of bottom plate for 854 two pieces tank mine is cracked will take whole tank if one is available i have a replacement gasket already thanks
    • Bodean
      By Bodean
      Slow but sure turning the corner get big red back together waiting on transmission seals
    • rustyedge1
      By rustyedge1
      These belts have been hanging in my garage since last used I believe there off a 754 I used to have. Bought them new and didn't use much.
      Don't know why I took them off. Some fraying on top in a few places from use, also don't know why but selling as is and photo'd. 20.00 shipped if you can use them.
      PM for PayPal info or questions. 16" ID approx.
