Countdown To Christmas!
vikingex30
tranny trouble..
vikingex30
hello! i have a 10hp wheel horse with 3 gear + R. it says uni drive pat. no. 2988185.
i need new seals and bearings and one of the gear fork has broken. it was stuck and broke when i took it appart. how to find new ones?
vikingex30
my english is bad so hope u undestand what i meant..
Anglo Traction
Velkommen VIKINGEX30 :WRS: Lars will be a Happy man when he sees another :norway: Member on here!.
Can you give us the Model Number of your Tractor ?. Your written English is good and I'm sure we can help solve your problem with parts.
Lars
Hey velkommen til :rs: here u can get the help u need..
Yes Richard it is fun to se one more member from :norway: .. So i dont feel so alone here
wheeledhorseman
Hei og Velkommen til
:rs:
:woohoo: Another new Euro member!
It's always good to post a photo to help with identification (really it's because we like looking at other peoples tractors)
BTW your english is very good!
Andy
racinfool40
Welcome..And I have to say pics are worth a thousand words..I should have everything you need..seals bearings and shift forks..post some pics if ya can and let me know what all you need..
Shipping won't be a problem but it's kinda pricey..I have shipped many a parts to Knursen..Lars in Norway.
Mike
AMC RULES
:norway: :WRS: :norway:
vikingex30
thanks for the varm welcome :) trying to upload some pics but they are to big
modell no is 71-10K4
out try taking some pics with the phone..
vikingex30
post-7160-0-44521000-1336418203_thumb.jppost-7160-0-96639900-1336418244_thumb.jp
post-7160-0-18349600-1336418378_thumb.jp
post-7160-0-75842900-1336418469_thumb.jp
post-7160-0-51236900-1336418542_thumb.jp
post-7160-0-33920800-1336418632_thumb.jp
vikingex30
the tranny was full off water when i got it and 2-3 gear was stuck.
racinfool40
Ouch!!! I can say That's the 1st time I have seen that happen to a shifter fork....I have a few of them also.looks like your gonna need a 3/4 input shaft sel a 5/8 brake shaft seal and 2-1" axle seals..Hows the bearings look??? I have all the seals and shifter forks and I do Have some 1" axle needle bearings also..Let us know what all you think your gonna need. As far aa everything else give it a good cleaning and we caqn go from there.
mike
vikingex30
some of the bearings are stuck so i shuld change all off them. sounds great! :)
Coadster32
Perhaps I'm mistaken, but I'm pretty sure the brake shaft is the same seal as the axle seals. (Might want to check b-4 ordering.) Good luck and welcome to RS.
vikingex30
i will. thanks :)
racinfool40
Yes. it depends on where your brake hub is mounted, I couldn't tell from your pics, If the brakes hud is mounted close to the axle tube then you will need another 1" seal..My Mistake I should have stated that before.. But in any case I do have them also..
MIKE
vikingex30
it is on the left side in front of the axle. you can se it on the pics. on the pics with the diff to the right and the gears to the left it is on the outside off the gears.
Lars
Auch this is not looking good..
do u have a pict of the tractor too?
Anglo Traction
Look's like the Tranny could be a 4 speed Unidrive with Brake Shaft in similar position as an 8 speed. I think it could be a 3/4"dia (19mm) Seal/needle Bearing on the Brake Shaft? :confusion-shrug: . Vernier Calipers anyone !. Good of you to offer your services Mike :handgestures-thumbup:.
can whlvr
i think you are wise to replace all the bearings,maybe the big set ,the 1533 bearing might be salvageable,but do the rest while you are in there
roger
I have a uni drive  pat. number 2988185 for sale. 80.00 call  1 330-626-3131
