brybrychrismer 17 #1 Posted May 6, 2012 While mowing with the C120 i kept smelling gas. On the last pas i looked down to see fuel pouring out. I found the problem to be the rubber gromet has a tear in it. So here is my question where can i get a replacement for the gromet? Thanks B.A. Share this post Link to post Share on other sites
WH854 44 #2 Posted May 6, 2012 While mowing with the C120 i kept smelling gas. On the last pas i looked down to see fuel pouring out. I found the problem to be the rubber gromet has a tear in it. So here is my question where can i get a replacement for the gromet? Thanks B.A. Here you go http://www.rcpw.com/search/?quest=46-6560&search.x=0&search.y=0 Chas 1 Share this post Link to post Share on other sites
stevasaurus 22,692 #3 Posted May 6, 2012 I just got one from my Toro dealer along with a new pet-cock for a C121. Together they were about $20. :) Share this post Link to post Share on other sites
Sparky-(Admin) 21,300 #4 Posted May 6, 2012 Doesnt the C-120 have the smaller under hood tank, not the one under the fender? Do they still use the same gromet and shutoff? Mike.......... Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #5 Posted May 6, 2012 Doesnt the C-120 have the smaller under hood tank, not the one under the fender? Do they still use the same gromet and shutoff? Mike.......... Yes - it's the same bushing & shut-off. These parts can also be used to repair the older plastic tanks if the outlet is damaged or breaks off. Share this post Link to post Share on other sites
AMC RULES 37,125 #6 Posted May 6, 2012 While mowing with the C120 i kept smelling gas. On the last pas i looked down to see fuel pouring out. I found the problem to be the rubber gromet has a tear in it. So here is my question where can i get a replacement for the gromet? Thanks B.A. Here you go http://www.rcpw.com/....x=0&search.y=0 Chas Thanks for sharing the link Chas. Share this post Link to post Share on other sites
Kelly 1,029 #7 Posted May 6, 2012 I just stocked up on them, and the shut off valves, I buy from another source the gromets are I think $1.25 each the valve is about $3.50 I make a big order of parts at one time and shipping is cheap that way I think my last order was $97 shipping was $6 Share this post Link to post Share on other sites
brybrychrismer 17 #8 Posted May 7, 2012 cool thanks for all the reply's Share this post Link to post Share on other sites
Rooster 191 #9 Posted May 11, 2012 On one of mine the plastic tank is damaged from someone using a screw driver to pry the grommet out..any fix for that? Share this post Link to post Share on other sites
dwcphoto 7 #10 Posted May 23, 2012 On the Toro Master Parts list there's a diagram for the electrical system. It shows to wires running together and only one is marked fuel sender wire. What's the other one? Thanks, d Share this post Link to post Share on other sites
liketoplayto 6 #11 Posted May 23, 2012 yeah u can go lowes and get some stuff like jb weld but for plastic it will seal up your screwdriver mess Share this post Link to post Share on other sites
