dave269
suburban 400 axle bushings?
dave269
where can I get the rear axle bushings for my 1960 suburban 400, the wheelhorse part is discontinued
VinsRJ
Both of the bushings (the one in the axel tube and diff carrier) can be found on Ebay or Amazon. Amazon has the cheapest prices on bronze bushings pretty much anywhere you will be able to find. Search the bearing size with the word "bronze".
I have also purcahsed the bushings off of Ebay. Again search the size. I have found sellers, selling the bushings for the same price as Amazon but in some cases with free shipping.
I can provide you with the Amazon part numbers if you are unable to locate the bushings.
dave269
would you be able to set me up with the ID & OD of these bushings , i'm going to change the differential bushings while i'm here. thanks Dave.
dave269
can you get me the pt#'s for the bushings,need to order them this week
VinsRJ
And the info is....
RJ/Suburban Input and Brake Shaft Seal: Timken/National #471643 (.750 x 1.624 x .250)
Suburban Brake Shaft Seal: CR/SKF #7410 (.750 x .999 x 1.004)
RJ/Suburban Axel Seal: #83-2840 / Toro Part #: 1257 (I tend to get these from Jacks Small Engines, not the cheapest but always in stock)
Axel Bushing: 1 x 1 1/8 x 1 1/2
Carrier Bushing: 1 3/8 x 1 1/2 x 1 7/16 (You will find these in 2" or 4" lengths and will have to cut them down)
Cluster Gear Bushings: 3/4 x 7/8 x 3/4
Gournd Bearings are: R-12
Un-Ground Bearings are: MCMasterCar.com part # 6383K49
Sububan Brake Shaft Bearing: Torrington B1212
dave269
thank you very much !!! you have been a big help, thanks again !!!!!!!!
