73-18 automatic 8 #1 Posted April 18, 2012 I was cutting grass yesterday and I went to back up and the shifter felt weird and then it came out of the transmission. Question is do I have to tear the trany apart to fix this and how hard of a fix will this be ????? Share this post Link to post Share on other sites
rmaynard 15,608 #2 Posted April 18, 2012 Take the shifter boot off and look to see if the dog-point set screw is still there. It could have backed out allowing the shifter to pull out. Also, see this thread in FAQ and Mechanical Tips Share this post Link to post Share on other sites
73-18 automatic 8 #3 Posted April 19, 2012 Ok looks good but one other question When I put the shifter back in place it will got shift gears the transmission stays in neutral Share this post Link to post Share on other sites
bo dawg 516 #4 Posted April 19, 2012 I don't think you have the shifter in right. Share this post Link to post Share on other sites
73-18 automatic 8 #5 Posted April 19, 2012 Kinda hard to see with seat pan on just frustrated the tractor only has 250 hours on it Share this post Link to post Share on other sites
rmaynard 15,608 #6 Posted April 19, 2012 You're going to have to get a good view into the hole where the shifter goes and be sure that the shift arms are lined up correctly. Then insert the shifter only far enough to align the hole in the ball with the pin. Share this post Link to post Share on other sites
73-18 automatic 8 #7 Posted April 19, 2012 Cool thanks guy's I will try and get it fixed this weekend Share this post Link to post Share on other sites
can whlvr 993 #8 Posted April 19, 2012 like bob said,you need to get a good look,you will see the that the shifter has to go in the middle of the shifter blocks(dont know the real names)but if i recall they are kinda square looking,its an easy fix once you get it in the right place,i used lock tight on the nut that tightens to hold the screw in when it happened to me Share this post Link to post Share on other sites
73-18 automatic 8 #9 Posted April 19, 2012 Can you get the screw if it not there ( may have fell out??) Share this post Link to post Share on other sites
pfrederi 17,881 #10 Posted April 19, 2012 The setscrew that holds in the shifter is available from Toro, or a good hardware store or on line from McMaster Fastnal etc. It is a 1/4" NC (20TPI) dog point set screw 1 or 1-1/2 inch long will work. you use a 1/4 20 nut to lock it in position after you install and adjust it. Share this post Link to post Share on other sites
73-18 automatic 8 #11 Posted April 20, 2012 Thanks for all the help Share this post Link to post Share on other sites
tunahead72 2,432 #12 Posted April 21, 2012 Kinda hard to see with seat pan on You should be able to remove the shift cover plate (where the two gear levers pass through) to get a better look and easier access. You'll have to remove the shift knobs first, they should unscrew fairly easily. The cover plate is held on with four screws at the corners, try some WD-40 or PB Blaster if they're stuck. If you need it, I believe the set screw is part no. 1239. Share this post Link to post Share on other sites
