redidbull 54 #1 Posted April 17, 2012 I am not sure if this is where to put this. When I bought my 73 NO Name there was a piece of small chain wrapped around the right side out tie rod end. While using it this past weekend the chain fell off and the tie rod fell off sending the wheels in opposite directions. I was able to line the tie rod hole up with the spindle but it didn't pop or sap on so I had to reuse the chain. How is the tie rod suppose to hold onto the spindle? Should it snap on? Thanks for any help. Jim Share this post Link to post Share on other sites
rmaynard 15,820 #2 Posted April 17, 2012 Yes, they are pressed together. Short of replacing the tie-rod or the end (if it is replaceable) you will need to remove the tie-rod. Place the ball into the socket and using a hammer and a punch, peen the metal around the edge of the socket to hold the ball in place. Then get a replacement set of tie-rods to repair the tractor properly. Share this post Link to post Share on other sites
SousaKerry 502 #3 Posted April 17, 2012 Yeah don't waste your time get a new set, I've tried to fix several they fall apart in a week or less Share this post Link to post Share on other sites
KC9KAS 4,742 #4 Posted April 17, 2012 Here you go..... Make your own....much cheaper and probably stronger! http://www.mcmaster.com/#tie-rod-ends/=h5db2l 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,780 #5 Posted April 17, 2012 Place the ball into the socket and using a hammer and a punch, peen the metal around the edge of the socket to hold the ball in place. Then get a replacement set of tie-rods to repair the tractor properly. I've done a few with Bob's method and they have lasted a few years! Before I stick the ball back in the socket I put a good dab of grease in it. Mike.............. Share this post Link to post Share on other sites
Raider12 13 #6 Posted April 17, 2012 Use a Zip Tie, it works great and will last for years. Just ask me! You really should replace the part! Share this post Link to post Share on other sites
64s 83 #7 Posted April 18, 2012 I'm with Raider 12, you just reminded me that I "fixed" mine with electrical cord at least a year ago, if not longer. It works so well that I forgot about it. BUT, ......it really should be fixed correctly so that no accidents can happen. Share this post Link to post Share on other sites
redidbull 54 #8 Posted April 18, 2012 Thank you all. I will eventually fix it but really like the zip tie idea for the short term. Jim Share this post Link to post Share on other sites
BOWTIE 226 #9 Posted April 18, 2012 HELLO, I HAVE REPAIRED ORIGINALS TO LIKE NEW. TAKE A 3/8" LOCK WASHER AND SPREAD IT A PART AND GRIND A LITTLE OFF THE END. BEND IT FLAT AND SLIP IT OVER THE BALL,SQUEEZE IT BACK TOGETHER AND WELD IT TO THE TIE ROD. GRIND THE SIDES OF THE WASHER DOWN TO THE TIE ROD. OIL IT UP AND SLIP THE RUBBER BOOT OVER IT. IT WORKS GREAT. GIVE IT TRY IF YOU HAVE MIG WELDER. I CAN SEND YOU PICTURE OF A REPAIRED ROD IF NEEDED. BOWTIE@COLUMBUS.RR.COM BOWTIE IN OHIO 2 Share this post Link to post Share on other sites
cjtrott 6 #10 Posted April 18, 2012 I worked at the local shop until a few months ago, the adjustable ends are like four bucks and the non adjustable tierod (the whole thing) is between 25 and 30. They are pretty interchangeable as well. Do yourself a favor and just replace it. You will be glad you did. You could also by the new end and weld it on if you wanted a small project. That is what I am doing for a little rat rod horse I'm building. Share this post Link to post Share on other sites
squonk 42,005 #11 Posted April 18, 2012 Here you go..... Make your own....much cheaper and probably stronger! http://www.mcmaster....od-ends/=h5db2l That's what I did on my 704. They don't look factory but they work better than new. 1 Share this post Link to post Share on other sites
can whlvr 993 #12 Posted April 19, 2012 dont forget the old tried and true mecanics wire and a hose clamp,gonna try the washer welded method though Share this post Link to post Share on other sites
