hambone3476
Raider 12 hi/lo shifter
hambone3476
Stuck in lo - any ideas? Hi/Lo shifter loose not engaging.
At least it's moving!
Thanks - Carl in GA
can whlvr
sure sounds like a shifter fork,that happened to mine years ago(308,not a raider)and the fork had jumped off the collar that it slides into to move the gear,i had let someone use her and i think they forced the shifter
stevasaurus
Carl...looks like you may have to go into that trans. Before you do, there are some real good threads with pictures of what you are up against. Not a hard job with the help we have here on Red Square. Try doing a search in this section, or tomorrow I can find the links for you and post them. Do not force that shifter. Check back here tomorrow.
hambone3476
Thanks - I figured I would have to go into the transmission. the trans in lo range - the normal gears work OK. The hi/lo shifter itself is loose - flopping around.
pfrederi
Did you check to see if the roll pin that holds the shifter to the shaft coming out of the transmission is not broken.
stevasaurus
Here is a great link with pictures that may help you with your trans.
