hambone3476 0 #1 Posted April 15, 2012 Stuck in lo - any ideas? Hi/Lo shifter loose not engaging. At least it's moving! Thanks - Carl in GA Share this post Link to post Share on other sites
can whlvr 993 #2 Posted April 15, 2012 sure sounds like a shifter fork,that happened to mine years ago(308,not a raider)and the fork had jumped off the collar that it slides into to move the gear,i had let someone use her and i think they forced the shifter Share this post Link to post Share on other sites
stevasaurus 22,866 #3 Posted April 15, 2012 Carl...looks like you may have to go into that trans. Before you do, there are some real good threads with pictures of what you are up against. Not a hard job with the help we have here on Red Square. Try doing a search in this section, or tomorrow I can find the links for you and post them. Do not force that shifter. Check back here tomorrow. Share this post Link to post Share on other sites
hambone3476 0 #4 Posted April 16, 2012 Thanks - I figured I would have to go into the transmission. the trans in lo range - the normal gears work OK. The hi/lo shifter itself is loose - flopping around. Share this post Link to post Share on other sites
pfrederi 17,881 #5 Posted April 16, 2012 Did you check to see if the roll pin that holds the shifter to the shaft coming out of the transmission is not broken. Share this post Link to post Share on other sites
stevasaurus 22,866 #6 Posted April 16, 2012 Here is a great link with pictures that may help you with your trans. Share this post Link to post Share on other sites
